kiteflyer5
installing PSE10
Aug 4, 2012 7:00 PM
Tags: #photoshop #elements_10
Our daughters laptop with Windows 7 will read our new-in-the-box PSE 10 (I did not install it there).  While our desktop with Windows XP will not.  We want to install it on the desktop but can't.  The the windows disc, #1, shows up blank.  All of the system requirements stated on the box have been met.  When i attempt to load the disc, my drive stops responding.  How can I fix this?  Would it work to download the trial version of PSE10 and then use the codes from the box to activate to a full version?
    Aug 4, 2012 7:09 PM   in reply to kiteflyer5
    I downloaded the trial version and used it for 30 days.  Then when I bought a boxed version from Amazon, I just entered the serial number and activated it.  It worked but my version was English.  If your version is other than English then I don't know; otherwise it should work.
    The trial version is on Adobe website:  However, I am not sure if you can get both 32bit and 64 bit versions (less important though);  That is something you will need to find out but 32 bit versions works fine on XP system.
    Did you know that you can install PSE on two systems; Laptop and Desktop?  It is allowed.
    Aug 4, 2012 7:49 PM   in reply to kiteflyer5
    kiteflyer5 wrote:
    Good to know.  I will try it.  I should have mentioned that the dvd drive works for everything else.
    It could be that your PSE media is DVD while the drive on your system is CD-Drive!! Is it possible?  Old machines came with CD-Drive only AFAIK).  I had to buy an external DVD drive for my backups and other things.  Perhaps you could try getting an external USB hosted DVD drive to run your PSE media!!!!.  another option here.
    Also, you could use the workaround and that is to copy the entire media (whether DVD or CD) on to a pen-drive using your daughter's laptop and use it to install it on your desktop.  You should have one spare USB port to plug in the pen-drive on your desktop..
    Just a thought.
    Aug 4, 2012 7:53 PM   in reply to mytaxsite.co.uk
    thought a while
    Aug 4, 2012 7:58 PM   in reply to caicong
    caicong wrote:
    thought a while
    Weekends are always like that.  Team GB did well today (London2012) so we are puinch[ed] drunk and can't sleep.
    Aug 4, 2012 8:25 PM   in reply to caicong
    Just so's you know, caicong, everyone here is a volunteer, just another user like you, not an adobe employee. The few employees who poke their noses in here from time to time are clearly labeled with the employee badge.
