Srijit Banerjee
Query About Editing Workflow in CS6
Aug 4, 2012 10:25 PM
Hi..
I shoot in Sony HDR XR 150E Camcorder in 1920 X 1080. But I wan't to edit my project in 720p. The raw files are in ".mts" format. How do I achieve this?
Thanks.
    Aug 4, 2012 10:43 PM   in reply to Srijit Banerjee
    The usual suggestion is to edit in a sequence that matches your Source footage  ( native) and then export to what ever you want eg a 720p codecXXXXX.
    However...you can Create  a 720p sequence and edit your footage with in that.  There is an option you can set : 'Scale to Frame size'.
    I recommend the first method... but you may have your own reasons for doing otherwise.
    Aug 5, 2012 1:45 PM   in reply to Srijit Banerjee
    You can set the entire sequence to "Scale to Frame size".  as a Default setting.
    Aug 5, 2012 3:08 PM   in reply to Srijit Banerjee
    Hardware is not so powerful to do a Full HD Edit
    The resolution of the file will have little or no impact on the computer's ability to play the clips.  That's more a factor of the codec used and the specific parameters of that codec.  Meaning if you convert to 720 using the same codec, it'll be just as difficult to play back.
    Aug 6, 2012 8:36 AM   in reply to Srijit Banerjee
    My recommendation for situations like this is generally to get better hardware.
