Efratrozen
can I open files that was made in CS6 in older variation like CS4?
Aug 4, 2012 10:20 PM
the office that i work with is working with Illustartor & photoshop CS4 and they are going to open files that i will made in CS6, can it be done easly?
    Aug 4, 2012 10:37 PM   in reply to Efratrozen
    Yes, but features that are specific to newer versions aren't always preserved exactly in older versions (we try, but it isn't always possible).
    Aug 4, 2012 11:02 PM   in reply to Efratrozen
    If you flatten the image, then it shouldn't be a problem.
    But, if you go back far enough 16 bit/channel and 32 bit/channel aren't supported, even flat.
    Aug 4, 2012 11:38 PM   in reply to Efratrozen
    Efratrozen wrote:
    that is no problem since i have 64 bit…
    You may have misunderstood and you're confusing the OS mode of operation with the bit depth of image files.
    What you would need under that back-far-enough scenario is 8 bit files.
    Message was edited by: station_two
    Aug 4, 2012 11:42 PM   in reply to Efratrozen
    Efratrozen wrote:
    ohhh now i get it the cannel mode.
    so if i usually work with 8bit channel what does it means?
    You'd be fine then.    I edited my last post, which you will not have seen if you are using email to access the forum.  Edits to posts are not broadcast to email users.
