ktroutman@deweypub.com
Hyperlinks panel
Jun 8, 2012 9:02 AM
Tags: #cs6
InDesign CS6 - I have lost the hyperlinks portion of the hyperlinks panel.  All that is left is Cross-references.  How do I get it back?  There appears to be something invisible in the middle of the cross-references section but I can not click on it or move it.
    Jun 8, 2012 9:07 AM   in reply to ktroutman@deweypub.com
    Most problems that result in odd panel behavior can be fixed by trashing your preferences. See Replace Your Preferences
    But before you go that far, go to Window > Workspace > Reset <current workspace name> and see if that solves it.
    Jun 19, 2012 3:27 PM   in reply to Peter Spier
    I join ktroutman in singing your praises. I had exact same problem. The keyboard startup and preferences trashing fixed it; hyperlinks are back! Thank you.
    Aug 5, 2012 1:02 AM   in reply to Peter Spier
    Second option worked for me too. Thanks Peter - I tried everything before seeing this!
    Is it a bug that needs attention in the next update?
    PS Adobe Cloud subscription is fantastic value - particularly with the intro offer!
    Aug 5, 2012 5:14 AM   in reply to Arthursever
    No, or at least probably not. I'm not sure we understand all of the things that can damage prefs, but mostly they seem to be external to ID.
    Oct 26, 2012 6:57 PM   in reply to Peter Spier
    I can't see how this isn't a bug. I've seen this problem in a number of posts. I'm just about to trash my preferences to fix this thing.
    Jan 24, 2013 11:26 AM   in reply to lhwohl
    More simple way, just go into the sub-menu in the Hyperlinks panel, and check Small Panel Rows. The Hyperlinks will be back
    Feb 7, 2013 3:55 AM   in reply to ktroutman@deweypub.com
    I am also having this problem with the disappearing hyperlinks panel.
    I've tried trashing preferences and selecting small panel rows, neither are fixing the problem though.
    Any other ideas would be most appreciated.
