Timer countdown problem
Aug 5, 2012 1:35 AM
Hello:
I have made a behavior with a countdown timer. It works. But the problem is when I use it with two or more textbox the counter don't stop and begin to count at the same time. I need to stop the previous timer when you click over another timer (textbox). This is my code. Thank you very much:
property Waiting
property Working
property pNombre
global Seg
on getPropertyDescriptionList
  -- create an empty property list called pList
  set pList = [:]
  addProp pList, #Waiting, [#comment : "How much wait", #format :#integer,default:0]
  addProp pList, #pNombre, [#comment : "Member", #format :#string ,default:""]
  return pList
end
on BeginSprite me
   Working = False
  pNombre=sprite(me.SpriteNum).member.name
  member(pNombre).text="" & Waiting
end
on exitFrame me
  If Working then
    if Waiting-Seg <=0 then
      Working=false
      Seg=0
     -- put "the End" && Waiting+Seg
    else
      --Counting waiting
      Seg=the timer/60
      member(pNombre).text=""& Waiting-Seg
    end if
  end if
  go to the frame
end
On MouseDown me
    starttimer
  Seg=(the timer/60)--  Waiting
  Working=True
end
    Aug 5, 2012 10:23 AM   in reply to anjemalo
    All you need to do is send a message to the other sprites to stop counting using "sendAllSprites()".
    On MouseDown me
      sendAllSprites(#stop)  -- ******   Add this line to your handler. ******
      starttimer
      Working=True
    end
    on stop me    -- **** Add this handler  *****
      Working = false
    end stop
