Ok, I'm trying to install the newest of the new
ColdFusion 10 with SQL 2012 on MS Server 2012
I have seen some blog posts, but nothing on the forum. Is there an official thread or response from Adobe on the issue? I cannot get ColdFusion 10 to install. It breaks right on the initial load screen
Please let me know if there is another thread that I can look at, and if not, I will use this thread as I debug the issue.
CF is not supported on Windows Server 2012. System requirements:
http://www.adobe.com/au/products/coldfusion-standard/tech-specs.html
Windows 2012 is still release candidate, current release being Windows 2008 r2.
Am using CF10 with SQL 2012 OK.
HTH, Carl.
What with Windows Server 2012 being RC I am not aware of any CF (9, 10, Standard, Enterprise or other apps from vendors) being supported.
Even if CF did work on Windows 2012 RC, RC’s have a habit of expiring shortly after release to manufacture so it is not like you can deploy it anywhere to development or production.
Cheers, Carl.
Adam, i do not know what you are talking about either, lol. Id love feedbacj on what was so confusimg
Yeah, sorry that was a bit oblique. It'd be helpful it you game details of the breakage, like what it says on the screen, does it freeze or just exit, or whatver it is what goes into the install logs (if anything), Something... anything to go on.
If you want support from Adobe, though, you will need to raise a support ticket with them; they do not offer support via these forums (which they basically host, but offer very little input beyond that).
What they'd say though is "don't try it: it's not supported yet".
Adam
No worrys Adam! You were right - my post was vague.
I am not getting past the initial install screen. It stops right at 98% of the 'install anywhere' window.
In regards to opening a ticket, you are 100% correct - 'don't try it: it's not supported yet'. lol.
I was thinking about just copying the entire coldfusion directory from my 2008 R2 box onto the 2012 box and going from there. I think that I can get services created and what not.
I can keep everyone updated on my progress on this thread if the moderators are OK with it. If I should post elsewhere, please let me know
Mike
Yeah, I'd say sling you're findings up here. That's what I'd do (not that that's a particular recommendation in and of itself).
I've never tried, but if you install on another machine and then shift the files over you should be OK. You'll probably need to check through all you're XML config files for path-mismatches and stuff.
I have read - on Andrew Scott's blog (http://www.andyscott.id.au/2012/5/31/ColdFusion-10-will-not-install-on -Windows-Server-2012 & http://www.andyscott.id.au/2012/4/26/Windows-Server-2012-and-ColdFusio n-installation) - that you'll likely have IIS problems as well though.
Best of luck, anyhow.
Adam
I was able to get it up and running by replacing the installer's JRE with the most recent version from Oracle (JRE 7)
I detailed the steps I took here http://thefusionator.com/index.cfm?blogID=2
Hi All,
Thanks for sharing the articles and the related information.
Yes! it's true that, CF10 is not officially supported over Win2k12 --> http://wwwimages.adobe.com/www.adobe.com/content/dam/Adobe/en/products /coldfusion/pdfs/cf10/coldfusion10-support-matrix.pdf.
We are yet to take a decision on Win2k12 and Win8.
Thanks.
Rg,spsb84
http://blogs.coldfusion.com/post.cfm/coldfusion-10-support-on-windows- 8-and-os-x-mountain-lion
Does that indicate CF10 on Windows 2012 is also 3 - 5 months away?
Cheers, Carl.
CF 10 was not officially supported over Win8 and Mountain Lion, once released.
Reference:
As per the demand and necessity of the time, CF Engineering team is taking related decisions and therefore a time-frame of 3-5 months is showcased.
Post that time, if anyone still has concerns for the installers, they can approach Adobe CF tech support at: cfsup@adobe.com
Hope this helps.
Thanks.
Rg,
Spsb84
Can you say that again in plain English, rather than trying to dolly it up in special officialese, rendering it basically unintelligible?
Oh god. So if it's not bad enough that you can't get CF to work, you expect people to go through the self-flagellation exercise that is talking to Adobe support? You are a very mean-spirited person ;-)
Adam
Hi Adam,
CF 10 is officially released to work on certain specific and tested OS's. If any individual/organization wish to go-ahead with CF deployment on an un-supported platform, it's their call.
Win8 got released and citing global acceptance and requirement {adding to large Customer base}, CF engineering is making efforts to support CF10 on Win8 and thus there has been a timeline of 3-5months for the new installers, shared across.
Once this is done, global community would be knowing about it too. But, sif anyone still has any related cocnerns then, Yes! you are welcome to reach adobe CF tech support at: cfsup@adobe.com
Hope this clears everything.
Spsb84
http://thefusionator.com/index.cfm?blogID=2 it's up here again - site was down over the weekend. I can get CF installed, but can't configure IIS. My installer doesn't create the wsconfig directory - so I have to copy across the one provided, but I get warnings when adding the virtual directories in IIS about permissions - so I don't think the ISAPI file can be accessed right. Here is what I get when I run a test CF page / the CF admin:
Service Temporary Unavailable!
The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.
Jakarta/ISAPI/isapi_redirector/1.2.32 ()
Windows permissions are not my forte - if anyone can fathom a workaround it'd be great. I'm pretty sure this should work, but I just don't really know how to fix the security things.
NB. When you're replacing the JRE in the installer make sure you use the very latest version, I used 7u9 I think. I tried a version marked just plain 7 and it didn't work - the link in the post doesn't work. You need to do the compatibility thing right too.
No idea why Adobe can't sort this very quickly indeed. Just build a new installer - will be all of a couple of days work - a week at most?!
Cheers, Henry
Just had the same issue setting up on a rackspace cloud server!
Decided that rather than rebuild with 2008 R2 I'd try something off the wall - Install Railo!
Worked perfectly - This could be just the kick I needed to shift away from Adobe - They're too slow to respond in my eyes and I've only heard good things about the Railo team and 3-5 months to change to a different installer and write a new IIS interface - Absolute cack!
