indention on my dynamic menu?
Aug 5, 2012 11:15 AM
Tags: #dynamic #module #menu #business_catalyst #bc
http://kellyandolive.businesscatalyst.com/aboutus.html
see link....this is driving me CRAZY. I can't figure out how to remove the indention from my menu? It should be even with the logo above it. I've tried switching out the style, and no matter which style I use there is an indention, bullet or both. I figured out how to remove the bullet using the list style type (none) but it leaves the indention and I'm about to go crazy.....please help me!!!
  • Liam Dilley
    Feb 28, 2012
    Aug 5, 2012 1:15 PM   in reply to NoelleMDesign
    Could have kept this in the same thread ^^
    You doing this in Muse or something?
    You have no styles on the ul and thus by default it is indented because it has padding.
    #nav_1325710  { padding:0; }
    In your stylesheet ill fix it up for you.
    Also:
    You got a class on every li, you add that each time? You can just target the UL then li in your css more effeciently like:
    #nav_1325710 li {}
  • Liam Dilley
    Feb 28, 2012
    Aug 5, 2012 4:33 PM   in reply to NoelleMDesign
    With firebug if I add it inline it sorts it, I see no styles in a stylesheet added to it. You sure your doing it right?
