With previous versions of Framemaker, I had a FrameScript which would loop through my document and add a marker to text based on the paragraph format applied. The marker text would be the selected paragraph.
I am now trying to recreate this in Extendscript for use in Framemaker 10 and am completely stumped.
I have no doubt that my script (copied below) is completely off-track, but I wondered if anybody would be able to help point me in the direction of my many mistakes.
Basically, I want the script to find all paragraphs with the "*Part no." format applied, make that text the text range and then apply a marker to that range. A bit of research has shown that I probably need to create a list of paragraph formats, but I believe that I have far more problems than just that.
var pgfFmt1 = flow.GetNamedPgfFmt (*Part no.);
while (pgfFmt1.ObjectValid())
function createMarker (doc, pgf, offset, type, text) {
var tRange, marker;
tRange = pgfFmt1.TextRange;
marker = doc.NewAnchoredObject(Constants.FO_Marker, tRange);
marker.MarkerType = type;
marker.MarkerText = text;
return 1;
createMarker (doc, pgf, 0, "Index", 0);
Many thanks in advance to anyone who is able to offer me some pointers!
If you have an working FrameScript you only have to bring that syntax to ExtendScript and particular a little bit more ;-)
But there is your algorithm, to find paragraphs... and there are hints how to use the FrameMaker object model
Searching for paragraph in a document works like this pseudo code:
var pgf = app.ActiveDoc.FirstParagraphInDoc;
while (pgf.ObjectIsValid()
if (pgf.Name != 'Partno')
pgf = pgf.NextParagraphInDoc;
continue
//do code for setting markers
Well, it seems that my script is only 95% there. While my script finds the target paragraphs and adds a marker, only the first word of each paragraph is selected as the marker text. I really need the script to select the whole paragraph as the marker text. I have tried many combinations, but cannot seem to get the right outcome. Could anybody please point me in the right direction? Script is copied below. Many thanks!
var doc = app.ActiveDoc;
var flow = doc.MainFlowInDoc;
var tframe = flow.FirstTextFrameInFlow;
var pgf = tframe.FirstPgf;
var target1 = doc.GetNamedObject(Constants.FO_PgfFmt, "*Part no.");
var target2 = doc.GetNamedObject(Constants.FO_PgfFmt, "*Parent Bold");
var target3 = doc.GetNamedObject(Constants.FO_PgfFmt, "*Child");
var target4 = doc.GetNamedObject(Constants.FO_PgfFmt, "*Child indent");
var target5 = doc.GetNamedObject(Constants.FO_PgfFmt, "*Child indent 2");
while (pgf.ObjectValid()) {
if (pgf.Name == target1.Name) {
createMarker (doc, pgf, 0, "Index", "");
else if (pgf.Name == target2.Name) {
createMarker (doc, pgf, 0, "Subject", "");
else if (pgf.Name == target3.Name) {
else if (pgf.Name == target4.Name) {
else if (pgf.Name == target5.Name) {
pgf = pgf.NextPgfInDoc;
function createMarker(doc, pgf, offset, type, text) {
var tLoc = new TextLoc(pgf, offset);
var marker = doc.NewAnchoredObject(Constants.FO_Marker, tLoc);
var markerType = doc.GetNamedObject(Constants.FO_MarkerType, type);
marker.MarkerTypeId = markerType;
return 1;
You can use the following function to get the text from a FrameMaker paragraph.
function getText(textObj) {
var objText = "";
// Get a list of strings from the object.
var textItems = textObj.GetText(Constants.FTI_String);
// Concatenate the strings.
for (var i = 0; i < textItems.len; i += 1) {
objText += (textItems[i].sdata);
return objText;
Once you add it to your script, you can modify each call to createMarker to something like this:
createMarker (doc, pgf, 0, "Subject", getText(pgf));
--Rick Quatro
