Administrator privilege are required to install Adobe Master CS5.5
Aug 5, 2012 7:46 PM
Hi All,
This is Tom. I'm logged in as local administrator to Windows 7 64bit OS and everytime I tried to install CS5.5 Master I kept getting this message, "Administrator privilege are required to install". Do you have any suggestion? I can install any program but just not CS5.5.
Thanks & Regards,
Tom
  • Noel Carboni
    Dec 23, 2006
    Aug 5, 2012 8:01 PM   in reply to tom.do.sg
    Did it ever show you a UAC prompt, requesting permission to escalate privileges?
    What happens if you try to install it by running the installer As Administrator?
    I suspect if this doesn't help you may have a permissions problem on a Users sub folder somewhere.  Do you dual boot, or have you done anything with multiple different user accounts?
    -Noel
    Aug 6, 2012 12:52 AM   in reply to tom.do.sg
    Could be a permissions issue with one of the global shared or temp folders. The install log may reveal something abou that.
    Mylenium
  • Noel Carboni
    Dec 23, 2006
    Aug 6, 2012 6:14 AM   in reply to tom.do.sg
    tom.do.sg wrote:
    It did not show UAC prompt as I am running as a local admnistrator.
    You may not understand how UAC works.
    Running things when logged into an account in the Administrators group is not the same as running something As Administrator.   Right-click the installer file, and choose Run As Administrator.
    If this is what you have done, Mylenium's advice is indeed valid - see what's actually failing.
    You could also try installing via the other account on your system.
    -Noel
