Missing Preview Icons
Aug 5, 2012 10:57 PM
Whenever I save a file in Photoshop CS6, no preview icon is created.  I am still also using PS CS5 and don't have this problem.  I am running Mac OS 10.8
    Aug 5, 2012 11:20 PM   in reply to enigma51564
    What are your Photoshop > Preferences > File Handling settings?
    What previews are you talking about axactly?
    Aug 6, 2012 5:34 AM   in reply to enigma51564
    A screenshot would seem to be so much easier and not as incomplete …
    Aug 6, 2012 8:07 AM   in reply to enigma51564
    See this thread about the non-displayed icons on OS X problem:  http://forums.adobe.com/thread/1008694?tstart=30
    I did some poking around and found that the icons attached to Ps CS6-saved files are unlike the icons attached to Ps CS5.1-saved files and files saved by other applications. This CS6-type icon is counter to recommendation in Apple's software development guidelines.
    A change was made by Adobe software engineers which results in different icons to those on CS5.1-saved files. You'll see that an attempt has been made to blame Apple for the icons not being displayed sometimes on some users' systems. However, if correctly-generated guideline-compliant icons are used then they will be displayed, as far as I know, since only Ps CS6 amongst thousands of apps seems to affect anyone. I think an update to Ps CS6 will see good icons being attached in future.
    In the linked thread, some users seem to have found a solution (perhaps only temporary, but I don't know).
    An alternative suggestion I can make is replacing the poor icons with good ones.
    The impractical laborious method:
    1. Using Photoshop, open the file that has a problem icon
    2. Select all
    3. Copy Merged, or Copy if Background is only layer (so the clipboard contains a composite)
    4. Close file
    5. Open Finder's Get Info window for the file
    6. Click the thumbnail at top-left of Get Info window (thumbnail border should highlight)
    7. Paste (OS X will generate and attach a good icon)
    8. Close Get Info window
    That may be Applescript-able for a batch process.
    I have a command line utility that can replace icons, and a batch process could be scripted, but icons are being displayed correctly on my OS X 10.6.8 Mac so I haven't bothered to do that.
    Regardless of how you change an icon, if the file is resaved by Ps CS6, a poor icon will be attached again.
