Failure to install AIR 3.3 application into iOS simulator
Jul 31, 2012 8:15 PM
Tags: #osx_lion #air_3.3 #osx_10.7 #ios_simulator
When I try to install the app into the simulator (adt -installApp) I get:-
Unknown or unsupported SDK version: /Developer/Platforms/iPhoneSimulator.platform/Developer/SDKs/iPhoneSi mulator5.1.sdk
I'm using Mac OS X 10.7.4 (Lion) and I'm trying to use the iPhone simulator as per support for iOS simulator blog post. I've tried different versions of the sdk (5.1,5.0,4.3,4.0) and I get the same result.
I'm using Flash Builder 4.6 and I've updated the sdk to Air 3.3 as per this article and I've extracted the sdk from XCode 4.4 per this article.
What am I doing wrong and what do I need to do to get it working?
  • Chris Campbell
    May 4, 2010
    Aug 1, 2012 5:21 PM   in reply to Chris Velevitch
    Forwarding to the iOS team for their review.
    Chris
    Aug 2, 2012 10:39 PM   in reply to Chris Velevitch
    Hi Chris,
    You are on OSX 10.7.4. You do not need to use hack provided here
    Using such hacks is not supported. Instead, you could provide the path to the mounted Simulator path or drag the XCode.app to /Applications and use this path:
    -platformsdk /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneSimulator. platform/Developer/SDKs/iPhoneSimulator5.1.sdk
    This should work.
    Aug 2, 2012 11:47 PM   in reply to Chris Velevitch
    Ok,
    By mounted path, I meant that the recent XCode versions don't get installed as earlier, but the .app is mounted.
    Can you provide the command that you are using to package and install the app on Simulator?
    Aug 3, 2012 12:09 AM   in reply to Chris Velevitch
    Please also share the packaging command.
    Aug 5, 2012 11:47 PM   in reply to Chris Velevitch
    Can you send me your project files, at neh@adobe.com
