I have a few imported images in my library I'd like to use as a mask to fit over a video but I can't get it to work. Here's how it works so far. The imported image is a photoshop .psd with some transparent layers.
import flash.display.Sprite;
import flash.media.Video;
import flash.display.MovieClip;
public class Main extends Sprite {
public function Main() {
private var video:Video = new Video();
private var dot:MovieClip = new Symbol1();
video.width = 160;
video.height = 90;
video.x = 443; //Video position
video.y = 190;
addChild(video); //Add video to stage
dot.x = video.x;
dot.y = video.y;
addChild(dot);
video.mask = dot;
This doesn't work. The video just gets masked by the whole image, and not the shape with the trasparent layer.
So I figure I'd have to convert the psd to a bitmap, cause it sounds like you can only use bitmaps. So I just draged the psd image into flash to get a bitmapdata file in my library. But it still doesn't work. Here's the new code:
private var dot:BitmapData = new Bitmap6;
public function main {
video.y = 190;
dot.x = video.x;
dot.y = video.y;
addChild(dot);
video.mask = dot;
but now I get these compiler errors:
1119: Access of possibly undefined property x through a reference with static type flash.display:BitmapData. | |
1119: Access of possibly undefined property y through a reference with static type flash.display:BitmapData. | |
1067: Implicit coercion of a value of type flash.display:BitmapData to an unrelated type flash.display:DisplayObject. | |
So now I'm not sure what to do. Can anybody help me out?
Thanks, if anyone can help.
Nevermind, totally figured it out on my own. The image needs to be imported as a png or as a bitmap. Then:
private var dot:BitmapData = new Symbol1();
private var mymask:Bitmap = new Bitmap(dot);
video.width = 160;
video.height = 90;
video.y = 190;
video.cacheAsBitmap = true; // this is pretty important
mymask.cacheAsBitmap = true;
mymask.x = video.x;
mymask.y = video.y;
addChild(mymask);
video.mask = mymask;
Well... thanks anyway to anyone.
