IvanJoghi
How to cast a (custom) string value to a number
Aug 6, 2012 1:23 AM
Tags: #flex #3.5 #string_to_number
Hello fellow Flex'ers,
I have a question regarding a revision number value which we respresent in our application as 2 digit number.
We are using 01-99 for revisioning, the number should be incremented each update.
I am adding document A with revision 01 (lowest revision), when finding this document and updating it I wish for my array to only show revision 02-99.
Basically I wish to remove the old values from my array. in my documentnumber.as file the revision is set as a string value.
My count function looks as follows (the data is being sent as XML):
[Bindable]
public var revisionDataprovider : ArrayCollection = new ArrayCollection();
[Bindable]
public var revisionUpdateDataprovider : ArrayCollection = new ArrayCollection();
                                           private function count():void
                                                            var i : int = 1
                                                            for (i; i < 100; i++)
        var revisionVersion : String = "" + i;
        var revisionUpdateVersion : String = "" + i;
        if (revisionVersion.length != 2 )
        revisionVersion = "0" + revisionVersion;
        revisionDataprovider.addItem(revisionVersion);
        trace("adding item: " + revisionVersion)
        if (revisionUpdateVersion.length != 2 )
        revisionUpdateVersion = "0" + revisionUpdateVersion;
        revisionUpdateDataprovider.addItem(revisionUpdateVersion);
What I want is that revisionUpdateVersion starts with the value from the old version which is set by the database as the value:pm.fml.documentNumberOld.revision
pm.fml.documentNumberOld.revision is the value in XML which is currently a string, it will not add up properly since it will add the revisionUpdateVersion as String {"" + 1} which will generate 011. I wish to casthe old revision to a number 01 = 1 (as int/number which will then count 1 + 1 = 2 and then the function will make it 02 by adding the 0+ revision version.
To clarify revisionVersion is used to generate the document revision and revisionUpdateVersion to update the created document.
I apologize if my question is vague. However I tried many things and cannot get it to work. I hope someone knows the answer
Thank you all in advance,
With kind regards,
Ivan Joghi
    Aug 6, 2012 4:09 AM   in reply to IvanJoghi
    You could use the 'parseInt(..)' method to convert the revisionVersion to a number.
    I.e.:
    var revisionVersionNumber:int = parseInt(pm.fml.documentNumberOld.revision);
    var rivisionUpdateVersionNumber:int = revisionVersionNumber + 1;
    var revisionUpdateVersion:String = ""+revisionUpdateVersionNumber;
    if (revisionUpdateVersionNumber<10) {
         revisionUpdateVersion = "0"+revisionUpdateVersion;
    Aug 17, 2012 12:53 AM   in reply to IvanJoghi
    Well, I thínk I understand what you're trying to say.. But it's impossible to pinpoint the problem with just this information.
    Could you post the code from where the user hits the Retrieve-button, up to the point where the documentNumberOld.revision-value cannot be set?
