RH 10 Index Links don't work
Aug 5, 2012 3:07 AM
Tags: #search #index_links
Hi All,
I have just downloaded RH 10 for trial.
I have created a WebHelp project from a Word 2010 Manual.
Two questions so far....
1. Index links don't work.
2. Search (tab) doesn't work. Points to the manual.
What have I been doing wrong/not doing...?
TIA,
Ofer.
    Aug 5, 2012 5:26 AM   in reply to Ofer Goren
    I'm guessing from the fact that this is your first post that you are new to RoboHelp rather than just RoboHelp 10.
    To be able to help you, we are going to need rather more information than you have given.
    Did you link the document or did you import it?
    The fact that your search is pointing to the document suggests your process is flawed. I am wondering if maybe you have just created a hyperlink to the Word document, that is not the same as Linking from the File menu.
    Have you seen the instructions on my site about those processes for RoboHelp 9? The process is pretty much unchanged.
    @petergrainge
    Aug 5, 2012 5:48 AM   in reply to Peter Grainge
    In addition to Peter's and Rick questions: What do you want to accomplish? Do you want to make an ebook with a Captivate demo for Kindle? Or do you want to make a video that can be played on the Kindle Fire?
    Greet,
    Willam
    Aug 6, 2012 12:37 AM   in reply to Ofer Goren
    When you reply, there is a camera icon in the toolbar. Use that to insert a screenshot of what you are seeing.
    @petergrainge
    Aug 6, 2012 2:32 AM   in reply to Ofer Goren
    Then please follow via the web.
    You said "In all projects, the Search option (tab) does not work properly. The searched strings are marked – but I am expecting a linked list of locations…"
    Please screenshot that. You can only add screenshots via the web, not email.
    @petergrainge
    Aug 6, 2012 3:58 AM   in reply to Ofer Goren
    I think I can guess what is wrong here. The search is saying that only one topic contains that word. I suspect that when you imported you only created one topic.
    In the workflow for importing there is a button under Word Documents that is labelled Edit.
    By default the whole document will import as one topic, If you click Edit you will be able apply Paginate against styles and RoboHelp will create separate topics based on that. So if you paginate at Heading 1 and there is only one such heading in the document, you will only get one topic, if there are five such headings, you will get five topics. You can paginate against any style.
    This is all explained in the topic I pointed you to earlier.
    @petergrainge
    Aug 6, 2012 6:52 AM   in reply to Ofer Goren
    Trash the old import and start over.
    @petergrainge
