lightroom 4.
Every box in filmstrip or main is greyed out.
tried optimizing catalog, tried launching other catalogs.
all is the same. i cant see any pics no matter what i do
i re-installed the display driver. no help.
everything else on the computer looks fine.
its weird. histograms show in devolop module, and the folders show on the botttom.
nothing reporting as missing.
anyone know where i can look in win 7 system?
Your monitor profile is corrupt. Ideally, you should get a hardware calibrator and calibrate your monitor.
As a stopgap measure until you can afford the $100 for the calibrator, go into Control Panel/Color Management and set your profile to "sRGB IEC6196-2.1", which is the vanilla sRGB profile. This won't give you "correct" colours, but it will at least let you see your images in "reasonable" colours. ![]()
Hal
It might be that the monitor profile is broken, try changing it to sRGB and see if it fixes the problem.
If it does, it is not a permanent solution but confirms that the monitor profile is the problem. You will need to create a new monitor profile with a hardware device like Spyder one or Eye one display. See the screen shot for the lcation of the monitor profile.
