I am getting the message "Flash cannot parse this document" when I try to open a particular file. I am hoping that someone has a fix for this error... I just lost 3 days of work if it can't be fixed.
If someone from adobe can look at the file maybe they can tell me what is wrong with it?
Kim
Hello,
Can you please email your fla to us at FlashAuthBetaBugs@adobe.com? Please note that our filter system cannot accept .zip file. If you are to zip your fla, please change the file extension from .zip to .zzz.
Quynh
Hi Quynh,
Immediately after I open the file, I get the following:
"An error occurred opening file 'C:\Users\Kimmy.... etc' and then in the
output window at the bottom it says "Flash cannot parse this
document."
Kim
Date: Tue, 22 Mar 2011 17:51:08 -0600
Subject: Re: "Flash cannot parse this document." "Flash cannot parse this document."
Hello,
Can you please email your fla to us at mailto:FlashAuthBetaBugs@adobe.com? Please note that our filter system cannot accept .zip file. If you are to zip your fla, please change the file extension from .zip to .zzz.
Quynh
Thanks Kim. Please install the Flash CS5 Updater. I believed we fixed this issue in that release.
Here's how:
1. Launch Flash.
2. Go to Help menu > Updates...
3. Make sure the box for Adobe Flash Pro CS5 is checked in the Adobe Application Manager dialog.
4. Click Update. You will probably be asked to quit Flash while the Updater is running.
You should be able to open the file without seeing the error.
The most common causes of this error message are
Fix empty frames tags in main timeline:
Unfortunately, there is no easy way to identify corrupt assets in a FLA file.
Hi!
I had 2 embed video in my fla. and I didn't open my *.fla next day in CS5. I was very angry and I tried open original fla (without video). Succeeded, then a I changed type of videos:
"Embedded (synchronized with Timeline) >>> Video (ActionScript Controlled)", Succeeded
This was my trouble because my 2 streamvideo symbols not supplied in CS5.
