roei
Supported video card with CS6
Aug 5, 2012 1:52 PM
Tags: #cuda #premiere #cs5.5 #export #encoder #cs6
I read in forums that the new CS6 encoder is supporting CUDA tech and if i export a H.264 file or Mpeg2 it'll be faster, In contrast CS5.5 that only in the premiere support the Marqury but if encodding with Encoder it slower. I want to know if it true and if i Have to buy the Supported cards in Adobe's list, becuse i want to buy the new GTX 670 and i didn't see it in the list, so what can i do?
    Aug 5, 2012 1:54 PM   in reply to roei
    [Moved to Hardware Forum]
    Aug 5, 2012 2:11 PM   in reply to roei
    First of all CUDA technology has been supported since CS5, so CS5.5 and CS6 all make use of this technology to use the GPU to accelerate the functions in this list.  Technically it does not do the H.264 and MPEG2 encoding, but if you apply any of the effects or features in that document it speeds up the encoding functions significantly..  Yes, you can use the GTX670 but you have to add one new line to the Adobe "cuda_support_cards.txt" file
    Aug 5, 2012 6:45 PM   in reply to roei
    Do not expect CS6 to be faster than CS5.5 the prime reason to go to CS6 is for new features
    With your CS5.5 are you currently using a CUDA card?
    Aug 6, 2012 3:09 AM   in reply to roei
    If you have the GT 540M (mobile) you are using a laptop and can't upgrade.
    Aug 6, 2012 4:07 AM   in reply to roei
    Tell us you plans in terms of components and budget and we may have suggestions.
    There is no need to upgrade to CS6, only a willingness if funds are available.
    Aug 6, 2012 4:30 AM   in reply to roei
    Adobe Forums: What PC to build? An update...
    For export you need:
    1. Fast CPU
    2. Lots of RAM
    3. Good disk setup
    4. ...
    5. ...
    6. ...
    7. ...
    8. ...
    9. Fast video card.
    Aug 6, 2012 5:05 AM   in reply to roei
    1. No.
    2. See:
    Adobe Forums: Planning / building a new system. Part 1
    or Planning & Building a new NLE System
    Have a look at the tab 'Disks, PSU'. Also look at the FAQ section here.
