shortcut keys to menu bar?
Aug 6, 2012 3:44 AM
Tags: #macpro #shortcut #cs6
Hi, I've looked everywhere on websites, forums.. I need to ask here since I can't find the answer.
What is the shortcut keys to "menu bar" on photoshop on mac?
I just want to go to the menus below, by using shortcut.
File
Edit
Layer
Type
Select
Filter
3D
View
Window
Help
Thank you!
    Aug 6, 2012 4:13 AM   in reply to visagold2
    First time Mac user?  Welcome to the Mac.
    It may come as a rude surprise to you, but we can't access the menus themselves via shortcuts.  The menu commands or menu items sure, but you can't get the menus to drop down through a key combination.  Sorry to be the bearer of bad news.
    Aug 6, 2012 4:51 AM   in reply to visagold2
    Not any that I know of.
  • Noel Carboni
    Dec 23, 2006
    Aug 6, 2012 8:25 AM   in reply to visagold2
    visagold2 wrote:
    sad
    Don't be too terribly sad...  PC users sometimes find that the Alt key combinations to activate menus (e.g,. Alt F to open the File menu) get in the way of using the Alt key as a modifier inside Photoshop.
    -Noel
    Aug 6, 2012 9:33 AM   in reply to visagold2
    Ctrl+F2 is the default to move focus to the Apple icon in the menu bar. Then press the initial letter of the desired menu or use arrow keys.
    If the system is set up so that the function keys act as media control keys then the fn key (above delete key) must be depressed to bypass the special features printed on the function keys. You can invert that behaviour in System Preferences for Keyboard to make the function keys easier to use.
    You can change the shortcut for menu focus in the System Preferences for Keyboard Shortcuts. For example, change from Ctrl+F2 to just F2.
    Aug 6, 2012 1:23 PM   in reply to conroy
    Visagold,
    To expand on what conroy 2009 shows above, once you have the Apple menu selected:
    • you can hit the down arrow to open the menu
    • move from menu to menu by using the right (or left) arrows and the menu will open on the new menu.
    • navigate items in the open menu by using the down arrow (this even works for flyout menu items) and hit return to "click" the menu command.
    Cycling through the menus work slightly different in InDesign and Photoshop.
    In Photoshop you can continually cycle just by using the arrow keys.
    However, in InDesign it appears that this process gets hung up when it arrives at the help menu.
    Of course the fastest way is to learn the most common keyboard shortcuts. A lot of users are so used to just using keyboard shortcuts that we would have to stop and hunt when we want to show someone how to do something only using the mouse to select keyboard commands.
    You can also go to the Edit menu and select Keyboard shortcuts to alter and add keyboard shortcuts to menu items that don't normally have them.
    Aug 6, 2012 6:18 PM   in reply to visagold2
    We have been working on bringing this to you for ps6! ill post it here first after we are done.
    -janelle
    Aug 6, 2012 11:07 PM   in reply to conroy
    Had not noticed that, conroy, thanks!
    Aug 6, 2012 11:36 PM   in reply to conroy
    That was an eye opener.  Thanks. conroy2009!
    Aug 6, 2012 11:39 PM   in reply to janelle_f
    janelleflores wrote:
    We have been working on bringing this to you for ps6!...
    We can assume you mean Ps 13, a.k.a. Ps CS6.  (Adobe does a thorough job of confusing customers with the version numbering!)
    Aug 6, 2012 11:51 PM   in reply to station_two
    Well, I guess many users did not actually work with Photoshop 6 back in the 90s so to those the distinction may seem irrelevant.
    Aug 6, 2012 11:52 PM   in reply to Noel Carboni
    Noel Carboni wrote:
    ...PC users sometimes find that the Alt key combinations...
    ...and some of us find it ineffective and futile to attempt to burden our old, atrophied brains with added key shortcuts to remember.
    That's why some of us jumped at the chance of being able to use a mouse decades ago.
    Aug 6, 2012 11:56 PM   in reply to c.pfaffenbichler
    Ah, but there are plenty of Elements users still using the not-so-old Elements 6, which the lower-case 'p' in jannelle's ps6 abbreviation might suggest.
    Aug 7, 2012 10:17 AM   in reply to visagold2
    ill make sure i will post in this thread once we decide where it will live
    janelle
    Oct 17, 2012 3:39 PM   in reply to visagold2
    ITS HERE!!
    For a reference to Adobe Photoshop's keyboard shortcuts, take a look at the new Photoshop CS6 Quick Reference Guide. It is in its beta form, but it is a great way to find shortcuts, as well as find a menu location that might have changed from CS5. We are looking for your feedback, which you can contribute on the site as well.
    janelle
    Oct 20, 2012 9:07 PM   in reply to visagold2
    the shortcuts are all listed under the mac and window columns. right now the shortcuts are just for the menus, we are trying to test of the effectiveness of the app.
    janelle
    Oct 21, 2012 5:00 AM   in reply to janelle_f
    janelle_f wrote:
    ... right now the shortcuts are just for the menus, ...
    I was hoping to find shortcuts for preferences, especially for darkening and lightening the Appearance: Color Theme. Any chance these could be included, or is there another reference for this info?
