I've never used an external style sheet before and I know I need to learn, so trying it now. I've linked my page etc, but I don't understand why the html tags aren't working... can I only put CSS styles in there? Can someone just explain the best practices here? Many thanks indeed.
CSS can be used in three ways:
1. Inline
2. Embedded
3. Linked as an external stylesheet
An example of inline styling would be - <p style="color:red;">This text is red</p>. It is the least desirable method of the three since it has embedded presentational information within your content (which is counter to the mantra currently important in web development to separate presentation from content). This example would result in ONLY that one paragraph's content being styled red.
An example of embedded styling would be -
<!doctype html>
<html>
<head>
<title>Embedded Styling</title>
<style type="text-css">
p { color:red; }
</style>
</head>
<body>
<p>This text is red</p>
<p>So is this</p>
</body>
</html>
This usage is very common. It's a better approach than inline styling since the presentational information is now separate from the content, but it's still not ideal since this style information can only affect this document and no others in your site.
An example of an externally linked stylesheet would be -
<!doctype html>
<html>
<head>
<title>External Styling</title>
<link rel="stylesheet" href="path_to_CSS_file.css" type="text/css">
</head>
<body>
<p>So is this</p>
</body>
</html>
The externally linked CSS file would be this (it can contain any number of CSS rules, but must not contain any HTML) -
p { color:red; }
It's ideal since any page in your site can then link to the file and immediately get the styling benefit of all of the CSS rules within that file.
Does that help?
Hi Murray! Thank you for explaining the different rules so nicely. Yes it helps... but can you explain why HTML tags aren't used in external css documents and where I should put them? Do they go on each page? I can't understand if my H1 tag is used throughout my website why it doesn't go in the external style sheet?
<h1> is an html heading tag. It doesnt go in the external css stylesheet, that contains css NOT html.
The css is used to position/style html elements.
As an example you would have the following in your stylesheet
h1 {
color: red;
margin: 0;
padding: 20px 0 0 20px;
and the following in your html:
<h1>This is a heading</h1>
thanks osgood... hopefully you can clear this up for me, this is what I have in my external style sheet:
@charset "UTF-8";
/* CSS Document */
<style type="text/css">
title {
font-family: "Times New Roman", Times, serif;
font-size: 28px;
font-style: italic;
color: #000;
h1 {
font-size: 20px;
font-style: italic;
color: #000;
h2 {
font-size: 14px;
color: #666;
p {
font-size: 14px;
color: #666;
small {
font-size: 10px;
font-style: italic;
color: #000;
</style>
and then this bit of code is for text in a table on my index page:
</table>
<table width="1142" border="0" align="center" cellpadding="0" cellspacing="0">
<tr>
<td width="82" class="small">Home</td>
<td width="123" class="small">How it works</td>
<td width="119" class="small">About us</td>
<td width="136" class="small">Testimonials</td>
<td width="165" class="small">Contact us</td>
<td width="354"> </td>
<td width="163">Our Privacy Policy</td>
</tr>
</table>
Why is this text not showing the design of what was established in my external style sheet? I really appreciate any help! Thank you so much!
Also, do css rules not have a dot before them? so why is it not .p { color:red; } in the external style sheet? Thanks again for explaining, there really isn't much help on so many 'help' websites, they just say "don't do this" but fail to explain to the beginner why or how it should be done.
You need a period '.' infront of class names
.small {
font-size: 10px;
font-style: italic;
color: #000;
But rather than keep applying the class name over and over again in your html, which can become bloated you could give the table an id like:
<table id="myTable" width="1142" border="0" align="center" cellpadding="0" cellspacing="0">
<tr>
<td width="82">Home</td>
<td width="123">How it works</td>
<td width="119">About us</td>
<td width="136">Testimonials</td>
<td width="165">Contact us</td>
</tr>
</table>
Then use the below css
#myTable td {
font-size: 10px;
font-style: italic;
color: #000;
p doesnt have a dot infront of it because its part of the html structure like <table> <div> <ul> <li>
you only need to use the . when a class is applied to the html structure like:
<table class="myTable">
<p class="myStyle">
<ul class="navigation">
etc etc.
Suzie8484 wrote:
Soooooo helpful! Thank you. So that period before the class name makes it a css rule, not an html tag.
Its known as a css selector:
.small {
Suzie8484 wrote:
What if I want google to recognise my h1 tags for important text in my site? Do I just use css like .h1? Does that still work? Thank you again! Really helping!
h1, h2, h3, h4 etc are part of the html so nothing is required infront of them
Suzie8484 wrote:
Ok, but when I put
h1 { ... }
rule in my stylesheet, dreamweaver won't let me select this as a style on my page unless i put a period infront of it. Thank you for your patience! Not sure what I would do without this forum and helpful people like you!
You dont need to select the h1 on your page for the styles to take effect if you define it in the css stylesheet. You only select an element on your page when you want to apply a class to it.
The two css selectors below will have the same results BUT you would have to select the h1 tag on your page and apply the .myHeading class to it whereas in the first example you don't.
h1 {
font-size: 20px;
color: #666;
<h1>A heading</h1>
and this
.myHeading {
font-size: 20px;
color: #666;
<h1 class="myHeading">A heading</h1>
That rule will select EACH <h1> tag on every page that uses this stylesheet. If you only want it to select a particular <h1> tag on the page (a page really should only have one <h1> tag), then you would have to qualify it somehow. For example -
Using a compound selector
CSS
h1.this { color:red; }
HTML
<body>
<h1>This text is black</h1>
<h1 class="this">This text is red</h1>
...or alternatively...
Using a descendent selector
body h1 + h1 { color:red; }
(this selector applies to any h1 tag that is next to an h1 tag that is within the body)
(see the above HTML)
Many thanks indeed. Now, for some reason, in my CSS styles panel, it isn't showing the first style that is on my external sheet. ie. h1 is first, but on the list of my CSS panel when i go to my page, it just isn't displaying and will not recognise <h1> in the code. I've tried changing the order - same thing, whatever is at the top is not listed in the panel? Why, oh why...!!
My external style sheet:
@charset "UTF-8";
/* CSS Document */
h1 {
font-size: 20px;
font-style: italic;
color: #000;
text-align: left;
h2 {
font-size: 14px;
color: #666;
title {
font-size: 28px;
font-style: italic;
color: #000;
p {
font-size: 14px;
color: #666;
small {
font-size: 12px;
font-style: italic;
color: #000;
font-weight: bold;
.toptable {
font-size: 16px;
font-style: italic;
font-weight: bold;
color: #FFF;
background-color: #000;
text-align: right;
.maintable {
border: medium solid #FFF;
a:link {
color: #FFF;
text-decoration: none;
a:visited {
color: #FFF;
a:hover {
color: #999;
text-decoration: underline;
a:active {
</style>
In the CSS styles panel for my page it shows:
h2
title
p
small
.toptable
.maintable
a:link
a:visited
a:hover
a:active
and if I change the order on my external style sheet, whatever is first seems to be omitted and not recognised at all - all the others work fine. Hope this helps.
