After countless problems with playback issues in Premiere I spent some time looking into what might be causing the problem on my system and it just seems like the way Premiere is handling cacheing is messed up.
As an example if I load a bunch of clips into FCPX throw them together in a timeline and hit play then watch my RAID I can see a steady read rate of around 50 MB/s. If I add more layers then the read rate goes up accordingly but the playback stays smooth because my RAID can deliver content at up to around 500 MB/s.
In Premiere Pro CS6 however it's a different story, the same process results in what looks like very random access to the RAID. Premiere seems to load footage into some kind of cache (RAM Buffer?) and then call up content in blocks as and when required. On my system this results in random read sessions up to 300 MB/s followed by a few seconds of inactivity from the RAID.
Whenever playback suffers a stutter or locks up it's usually just before one of these high speed reads which leads me to think that premiere is requesting the data in advance of the timeline needing it but it's arriving too late to keep the playback fluid.
I can't help thinkign that the simpler approach of streaming in the data as required works much better.
Mac Pro 12 core / 48GB Ram / SSD Boot Drive
SAS based RAID Storage
All NLEs require a RAM buffer in order to stream video (and audio) at a constant rate.
You could try some experiments with different RAM values in the Preferences.
But, I see the same thing you do, I think. I can shuttle/scrub sequences and even single clips in QT Player, Avid, FCP, etc., and it's smooth as silk. But, bringing them into Pr (also on Mac), it's an entirely different story. Lots of lag. Lots of dropped frames, both in the Source viewer, and in a matched settings Sequence with no effects or changes of any kind.
It's one of my few peeves about Pr.
My guess that this is due to the architecture Adobe chose when they decided to focus on native editing. All media is probably going through some process, even when it doesn't need it, such as when using intraframe sources.
Oddly enough, I get better/faster scrubbing with Long-GOP material than ProRes intraframe, even though I would expect it to be much worse. There's more data being shuttled normally with intraframe, and perhaps the buffers built into Pr just aren't as large as they should be. Or, perhaps the order of decode and load into RAM buffer is opposite of what it should be.
You can adjust the audio buffer in the prefs. Maybe what we need is an adjustable video buffer as well. Or, maybe Adobe could include some code that makes it larger when it detects as much RAM as you have.
Maybe somebody with more engineering know-how can offer some insight.
"I can shuttle/scrub sequences and even single clips in QT Player, Avid, FCP, etc., and it's smooth as silk. But, bringing them into Pr (also on Mac), it's an entirely different story. Lots of lag. Lots of dropped frames, both in the Source viewer, and in a matched settings Sequence with no effects or changes of any kind."
That's about the most depressing review anyone could offer of an NLE, since it involves virtually every T-L and editing operation.
Are folks experiencing much the same thing on PC platforms w/CS6?
Okay, wernt back and looked again, 50 MB's was the peak transfer not the average, well spotted! those are ProRes 422 files transcoded for FCPX and the average read was 16 MB/s.
I have to eat some humble pie here because I tried bringing the transcoded files from FCPX into Premiere and it handled them in much the same way as FCPX, ie as a steady data read from the drives. When premiere reads the native C300 files is when it handles the data loading in a different way resulting in the less steady data stream.
I really don't want to go back to transcoding everything to ProRes, but maybe that's the best way to stop premiere from locking up.
