Triangle
Aug 6, 2012 8:23 AM
Can anyone help as I would like to create an eps triangle with curves (instead of points) but don't know how. I've Illustrator version 8. Could someone do this for me for a tenner as I'm unemployed and quite skint at the moment. I'll pay by paypal if anyone can help. I need to open in Illustrator version 8
Ta.
Howard
    Aug 6, 2012 8:54 AM   in reply to dustnbones2
    You can draw a triangle easily by drawing with the polygon tool, and hit the cursor down a few time to reduces the amount of sides to 3.
    Illustrator 8 is quite old so to round the corners you will haev to do thsi manually as I beliueve the rounded conrers filter did nto exist yet. You can use the convert poitn too to round the conrers manually.
    Aug 6, 2012 9:58 AM   in reply to dustnbones2
    Howard,
    You may try the free Round Every Corner script and see whether it works for 8.
    http://park12.wakwak.com/~shp/lc/et/en_aics_script.html
    If it does, basically you create a circle with the desired diameter, use the Direct Selection Tool to select that and the corner points to round (drag over the entire circle, then hold Shift and drag over the anchor points to round), then press Enter.
    Edit: There seems to be a rift in the time space continuum.
