ambeexx
Installing the trial of Master Collection CS6 on mountain lion
Aug 5, 2012 10:59 PM
Tags: #error #x #adobe #lion #mac #install #apple #fail #collection #master #failed #installation #os #support #advisor #mountain #10.8
i keep having this problem no matter how many times i reinstall and redownload.
i keep getting the installation failed message.
I have followed everything i can find to try and fix the problem and nothing is working
i have been trying to download the trial for almost a week now.
here's the message that comes up:
    Aug 6, 2012 10:54 AM   in reply to ambeexx
    It appears you are having installation difficulties as opposed to problems downloading.  I would recommend reviewing your installation logs manually.  You can find details on how to accomplish this at Troubleshoot with install logs | CS5, CS5.5, CS6 - http://helpx.adobe.com/creative-suite/kb/troubleshoot-install-logs-cs5 -cs5.html.
    If you are still having difficulty please use the Package for Support option and respond to this thread with your token number.  I would strongly recommend though reviewing your installation logs first though as myself or other Adobe employees would be completing the identical steps as what is listed in the document.
    Feb 3, 2013 7:13 AM   in reply to ambeexx
    I am having the same problem.
    Feb 3, 2013 9:50 AM   in reply to bobbieturner
    Bobbieturner what error messages did you uncover when you reviewed your installation logs?
    Feb 4, 2013 8:51 AM   in reply to Jeff A Wright
    Jeff I get as far as MAC HD/Library/Logs and then I dont see adobe...
    Feb 4, 2013 2:04 PM   in reply to bobbieturner
    Bobbieturner I would recommend contacting our support team then if you are facing difficulties with locating the installation log files.
    Feb 5, 2013 8:19 AM   in reply to Jeff A Wright
    2/5/2013 08:56:24.791 [INFO] PDAPP.AppletManager Loading progress1048576 out of 1280212
    2/5/2013 08:56:24.792 [INFO] PDAPP.AppletManager Loading progress1114112 out of 1280212
    2/5/2013 08:56:24.812 [INFO] PDAPP.AppletManager Loading progress1179648 out of 1280212
    2/5/2013 08:56:24.814 [INFO] PDAPP.AppletManager Loading progress1245184 out of 1280212
    2/5/2013 08:56:24.815 [INFO] PDAPP.AppletManager Loading progress1280212 out of 1280212
    2/5/2013 08:56:25.146 [INFO] Deployment.D6FlexApplication Application load complete. Initializing the application
    2/5/2013 08:56:25.149 [INFO] Deployment.ApplicationStartup Processing the application startup
    2/5/2013 08:56:25.151 [INFO] PDApp.ExternalGateway Recieved Applet Loading Completion
    2/5/2013 08:56:25.152 [INFO] Deployment.ApplicationStartup Communication Manager initialized. Loading ZString
    2/5/2013 08:56:25.154 [INFO] ZStringLoader Trying to load ZString for preferred locale - en_US
    2/5/2013 08:56:25.180 [INFO] ZStringLoader Locale set to - en_US
    2/5/2013 08:56:25.180 [INFO] Deployment.ApplicationStartup ZString initialized with locale: 'en_US'. Starting deployment workflow.
    2/5/2013 08:56:25.190 [INFO] Deployment.ApplicationStartup Font fallback applied is applicationFonts 'Lucida Grande, Segoe UI, Tahoma, _sans' inputControlFonts: 'Lucida Grande, Segoe UI, Tahoma, _sans'
    2/5/2013 08:56:25.193 [INFO] Deployment.FetchMediaInformation Start fetching the payloads data
    Tue Feb  5 08:56:25 2013    [INFO] PDApp.AppletManager - Loading Applet - DWA_Native for WindowID - 1
    Tue Feb  5 08:56:25 2013    [INFO] DWANative - Build Version - 6.0.335.0
    Tue Feb  5 08:56:25 2013    [INFO] DWANative - Logging Level verbosity Set  to 4
    2/5/2013 08:56:25.284 [INFO] DeploymentNativeApplet Media Signature found as {74EB3499-8B95-4B5C-96EB-7B342F3FD0C6}
    2/5/2013 08:56:25.285 [INFO] Deployment.FetchMediaInformation Summary file created for troubleshooting at path: file://///tmp/E8CFBF49-4B0A-4BFC-AAB2-4665AD34A932/summary.htm
    2/5/2013 08:56:25.290 [INFO] DeploymentNativeApplet Setting System statistics data...
    2/5/2013 08:56:25.292 [INFO] Deployment.DirectoryTokens Extracting tokens for mac
    2/5/2013 08:56:25.294 [INFO] Deployment.DirectoryTokens Adding a token with name [AdobeProgramFiles] and value /Applications
    2/5/2013 08:56:25.294 [INFO] Deployment.DirectoryTokens Adding a token with name [AdobeCommon] and value /Library/Application Support/Adobe
    2/5/2013 08:56:25.295 [INFO] Deployment.DirectoryTokens Adding a token with name [Common] and value /Library/Application Support
    2/5/2013 08:56:25.295 [INFO] Deployment.DirectoryTokens Adding a token with name [ProgramFiles] and value /Applications
    2/5/2013 08:56:25.296 [INFO] Deployment.DirectoryTokens Adding a token with name [SharedApplicationData] and value /Library/Application Support
    2/5/2013 08:56:25.296 [INFO] Deployment.DirectoryTokens Adding a token with name [SharedDocuments] and value /Users/Shared
    2/5/2013 08:56:25.296 [INFO] Deployment.DirectoryTokens Adding a token with name [Utilities] and value /Applications/Utilities
    2/5/2013 08:56:25.297 [INFO] Deployment.DirectoryTokens Adding a token with name [FontsFolder] and value /Library/Fonts
    2/5/2013 08:56:25.297 [INFO] Deployment.DirectoryTokens Adding a token with name [Library] and value /Library
    2/5/2013 08:56:25.298 [INFO] Deployment.DirectoryTokens Adding a token with name [LibraryPreferences] and value /Library/Preferences
    2/5/2013 08:56:25.298 [INFO] Deployment.DirectoryTokens Adding a token with name [ScriptingAdditions] and value /Library/ScriptingAdditions
    2/5/2013 08:56:25.299 [INFO] Deployment.DirectoryTokens Adding a token with name [UserPreferences] and value /Users/turtlebobbie/Library/Preferences
    2/5/2013 08:56:25.299 [INFO] Deployment.DirectoryTokens Adding a token with name [UserCommon] and value /Users/turtlebobbie/Library/Application Support
    2/5/2013 08:56:25.300 [INFO] Deployment.DirectoryTokens Adding a token with name [UserHome] and value /Users/turtlebobbie
    2/5/2013 08:56:25.301 [INFO] DeploymentNativeApplet Checking whether the media with signature '{74EB3499-8B95-4B5C-96EB-7B342F3FD0C6}' has been run on this system
    Tue Feb  5 08:56:25 2013    [WARN] DWANative - Could not retrieve media signature from the arguments.
    2/5/2013 08:56:25.304 [INFO] DeploymentNativeApplet Fetching the setup manifest from media
    Tue Feb  5 08:56:25 2013    [WARN] DWANative - Error in getting pdbGetInstallState 4
    2/5/2013 08:56:25.599 [ERROR] DeploymentNativeApplet Payload list has no result top level tag: Return value is <error>Error in getting data from MDB</error>
    2/5/2013 08:56:25.602 [INFO] AAMShared.DynamicViewMediator Showing screen with screenID : SCREEN_INSTALL_FAILURE
    2/5/2013 08:56:25.674 [INFO] DeploymentNativeApplet Launch Successful
    2/5/2013 08:56:25.684 [INFO] Deployment.ScreenNavigationCommand Approximate total time taken in startup is 531 milliseconds
    Tue Feb  5 08:56:25 2013    [INFO] Setup - TimeLog: PDApp window came. Exiting
    Tue Feb  5 08:56:25 2013    [INFO] Setup - =================  Exiting Installer with Code: 0  =================
    Tue Feb  5 08:56:25 2013    [INFO] PIM - PIMSqlite closeDB status 0
    Tue Feb  5 08:56:25 2013    [INFO] PIM - FREE PIM Instance ...
    2/5/2013 08:57:49.517 [INFO] PDApp.HostMessageHandler Front applet found
    Tue Feb  5 08:57:49 2013    [INFO] PDApp.AppletManager - Un-loading Applet - DWA_Native for window ID - 1
    Tue Feb  5 08:57:49 2013    [INFO] PDApp.ExternalGateway - Callng the finalize function of the applet ID - DWA_Native
    2/5/2013 08:57:49.546 [INFO] PDApp.HostMessageHandler Recieved force window close message
    2/5/2013 08:57:49.547 [INFO] PDApp.HostMessageHandler Sending message to native
    Tue Feb  5 08:57:49 2013    [INFO] PDApp.WindowManager - Destroying window with ID - 1
    Tue Feb  5 08:57:49 2013    [WARN] PDApp.WindowManager - GetAPEWindowIDString failed, Unable to find PlayerRef!
    Tue Feb  5 08:57:49 2013    [INFO] PDApp - Last window destroyed quiting as event. Quiting application as an event (async)...
    Tue Feb  5 08:57:49 2013    [INFO] PDApp.WindowManager - Destroying PDApp main window with ID - 1
    Tue Feb  5 08:57:49 2013    [INFO] PDApp.WindowManager - DestroyAllAPEWindow failed, APE Window count is zero while destroying all APEWindow's
    Tue Feb  5 08:57:49 2013    [INFO] PDApp - Terminating MessageQueueManager
    Tue Feb  5 08:57:49 2013    [INFO] PDApp.AsyncMsgProcessor - Terminating AsyncMsgProcessor Message Queue
    Tue Feb  5 08:57:49 2013    [INFO] PDApp.MessageQuequeManager - Message Queue Manager destructed
    Tue Feb  5 08:57:49 2013    [INFO] PDApp - Terminating AppletManager
    Tue Feb  5 08:57:49 2013    [INFO] PDApp.AppletManager - AppletManager destructed
    Tue Feb  5 08:57:49 2013    [INFO] PDApp - Terminating WindowManager
    Tue Feb  5 08:57:49 2013    [INFO] PDApp - Terminating NativeCommandHandler
    Tue Feb  5 08:57:49 2013    [INFO] PDApp.ExternalGateway - NativeCommandHandler destructed
    Tue Feb  5 08:57:49 2013    [INFO] PDApp - Terminating NativePlatformHandler
    Tue Feb  5 08:57:49 2013    [INFO] PDApp.ExternalGateway - NativePlatformHandler destructed
    Tue Feb  5 08:57:49 2013    [INFO] PDApp - Terminating ExternalGateway
    Tue Feb  5 08:57:49 2013    [INFO] PDApp.ExternalGateway - ExternalGateway destructed
    Tue Feb  5 08:57:49 2013    [INFO] PDApp - Terminating APE
    Tue Feb  5 08:57:49 2013    [INFO] PDApp - Releasing all locks acquired
    Tue Feb  5 08:57:49 2013    [INFO] PDApp - Quiting Application
