i want to load external swf but it's give me error
TypeError: Error #1009: Cannot access a property or method of a null object reference.
at Main()
the code is
package{
import flash.display.Sprite;
import flash.events.MouseEvent;
import flash.net.navigateToURL;
import flash.net.URLRequest;
import flash.display.Loader;
public class Main extends Sprite{
private var _loader:Loader = new Loader();
public function Main():void{
mc_star.addEventListener(MouseEvent.CLICK,buttonClick);
mc_gear.addEventListener(MouseEvent.CLICK,buttonClick);
mc_apple.addEventListener(MouseEvent.CLICK,buttonClick);
mc_photo.addEventListener(MouseEvent.CLICK,buttonClick);
mc_buy.addEventListener(MouseEvent.CLICK,buttonClick);
mc_contact.addEventListener(MouseEvent.CLICK,buttonClick);
_loader=new Loader();
addChild(_loader);
private function buttonClick(e:MouseEvent):void{
var url:URLRequest=new URLRequest();
switch(e.target.name){
case "mc_star": url.url="bg2.swf"; break;
case "mc_gear": url.url="bg3.swf"; break;
case "mc_apple": url.url="bg4.swf"; break;
case "mc_photo": url.url="bg5.swf"; break;
case "mc_buy": url.url="bg6.swf"; break;
case "mc_contact": url.url="bg7.swf"; break;
_loader.load(url);
click file/publish settings/swf and tick "permit debugging". retest.
the line number with the null object will be in the error message. that will probably be one of your mc_ objects.
when you find which, return to your fla's stage and click the object you think should have that instance name and fix the problem.
use:
package{
//_loader=new Loader();
addChild(_loader);
_loader.load(url);
Thank you again for your help
all of this have a instance name
it's give me this error
at Main()
which is line 23?
mc_star doesn't exist.
return to your fla's stage and click the object you think is mc_star and fix the problem.
Thank you i fix the problem
you a great man
you're welcome.
p.s. please mark helpful/correct responses.
