NotTooFast
Interlacing is Ruining Quicktime Movies
Jan 20, 2010 9:26 PM
I have searched all over and can't figure out what I am doing wrong.
I have video taken with my Canon vixia HFS200 in 1920x1080 60i.  I use the Full HD 1080i 30 Project Preset.
When I export video clips to Quicktime formate, the interlacing is extremely bad.
Should I be shooting video in 1920x1080 30p, or should I be using a different preset?
Keith
    Jan 21, 2010 5:27 AM   in reply to NotTooFast
    Your camcorder is an AVCHD camcorder. You should be using the AVCHD project specs, not the HDV.
    Jan 21, 2010 6:37 AM   in reply to NotTooFast
    If you are capturing your video and using Premiere Elements with an AVCHD preset, I don't know why you're having interlacing issues.
    It sounds like you're using the correct workflow.
    Aug 6, 2012 1:10 PM   in reply to Steve Grisetti
    So.... more than two years later...this thread is still here... and there was no solution? I have the same constant problem ... and the only response is: "It sounds like you're using the correct workflow."
    Apparantly, this is a major problem with Elements - that has not been fixed?
    Aug 6, 2012 3:04 PM   in reply to EricWB
    I have never experienced this issue in nearly 10 years of using the program, Eric. So I don't know what's going on at your end.
    But if you can post a sampling of your video (about 30 seconds worth of raw footage, directly from your camcorder), I will be glad to see if I get the same results.
    You'll have to post the video to a download site though. Not YouTube or Vimeo, which transcodes the video into another format. I need to get my hands on the native AVCHD 1920x1080 60i video.
