stynkrbelle
Cs6  Trying to import .mov I keep getting the error "no audio or video streams"
Aug 6, 2012 12:47 PM
Tags: #error #premier #quicktime
I have 2 projects and I can not import .mov I keep getting the error msg "no audio or video streams"
    Aug 6, 2012 1:13 PM   in reply to stynkrbelle
    Where did the video come from?
    Can you play it on your computer at all?
    Download MediaInfo and use that to analyze the file - what is the codec info?
    Aug 6, 2012 1:17 PM   in reply to stynkrbelle
    This usually happens if Quicktime is not installed on Windows and the MOV files contain a codec that can't be imported by Premiere Pro's custom 64-bit Quicktime importer.
    Regardless, information about your platform and operating system is required, along with the info that Greg requested.
    Jeff
    Aug 6, 2012 2:26 PM   in reply to stynkrbelle
    I have been getting a message that I don't have Quicktime installed so I installed Quicktime 7 and I still get the same message
    That indicates that your Adobe apps (likely more than just Pr) aren't picking up the Quicktime installation.  You should try uninstalling, manually cleaning out any remnants of QT, and reinstalling.  If that doesn't work, then maybe reverting to an earlier version of QT would help.
    FWIW, I have QT 7.7.2 installed here with CS5.5.2 and they play nicely together.
    Jeff
    Aug 28, 2012 1:35 PM   in reply to stynkrbelle
    You need to CLOSE PREMIERE CS6.  Then install quicktime.  Then reopen CS6 and it should work.  This happened to me as well.
    Feb 28, 2014 9:15 PM   in reply to stynkrbelle
    I know this is an old thread, but this may still help someone having problems importing .mov files into Premiere Pro CS6 (or earlier versions) in Windows 7/8.
    - Go to control panel
    - Appearance and personalization
    - Folder options
    - View tab
    - Un-check Hide extensions  for known file types
    - Hit OK
    - Find your FILE.mov file and rename it to FILE.mpg
    Try importing the newly renamed .mpg file to Premiere and it should work. PP CS6 kept crashing for me, but once I renamed the file, it imported perfectly. Hope this helps.
