SwissKnifeMedia
Music slightly out of sync when exporting in Premiere CS6, format problem?
Aug 6, 2012 1:32 PM
Tags: #problem #help #out #audio #premiere #export #cs #of #format #6 #sync
Hi guys, i have a quick question.
I edited together a promo for a local band and everything is perfect in the sequence as far as being on point with the music at certain beats and such. However when I export it the music is slightly out of sync, which is bad when you edited everything specificly to the song. I am not using ANY audio from the footage but instead layed a music track over everything. I'm not sure what else to do, could it be a format problem? I am using h.264 (see below), but would AVI or anything else work better? any help is appreciated thank you!
I am exporting directly from inside Premiere CS6 using a custom H.264 preset. 24fps, VBR 2 pass encoding. Target 7MB, Max 11MB. (with render at maxium bit depth, and render at highest quaility selected.)
I put the audio settings to high, 320kbs AAC format.
I use a custom built PC with an i7-3770K, 32 GB RAM, and I exported to a 120GB SSD.
Any other info you need just ask.any types for uploading to vimeo so it doesn't get out of sync there? thank you in advance!
Also, any types for uploading to vimeo so it doesn't get out of sync there? thank you in advance!
    Aug 6, 2012 1:48 PM   in reply to SwissKnifeMedia
    Have you tried a Vimeo preset from AME?
    Aug 6, 2012 3:10 PM   in reply to SwissKnifeMedia
    I have the same problem!  I tried ALL different ways of fixing the issue but nothing works.  The only thing to do is nest the sequence and nudge the audio track so it's back on beat.
    Aug 6, 2012 3:25 PM   in reply to SwissKnifeMedia
    I dont think that you will really get a problem while exporting in any of the given formats. But i would really like to check if the audio layer is exactly same as of the video. for eg - if my audio is 00:05:30 and my video is 00:05:20 , we might face issue with the sync.
    We can try to put more black video to make it a match with the audio and then try to export.
    Where do you have the media files , on a internal drive like c: or desktop? In case not , try to move the media files to desktop and then try to export.
    Also instead of exporting the files to your 120GB SSD , try to export it on the desktop.
    Hope it helps.
    Aug 6, 2012 3:53 PM   in reply to SwissKnifeMedia
    Have you tried other settings? For computer, 30P is generally best, unless you shot in 24.
