LR Catalog strategy
Aug 6, 2012 8:59 AM
I'm in the process og starting LR. I've started importing the wole brunch of existing pictures. These pictures are on a set of NAS servers (7 servers). My first plan is to import all approx 10 TB picture in one catalog. I can see though that A) this will take really really long time (approx 1-2 week if 24-7 work and B) it will produce a preview catalog that is not manageable (a huge amount of files).
My naive thought was to have all pictures in one database and beibg able to search across the whole set of pictures.
So I got to think that perhaps there is another schema for using LR catalogs.
Do any of you have some general considerations or best practices on planning and using LR catalogs?
-- Søren
    Aug 6, 2012 10:09 AM   in reply to Søren Langkilde Madsen
    Why divide up the control of your picture collection? LR works best as one main catalogue managing all your work / workflow, and a single catalogues can record hundreds of thousands of pictures.
    Aug 6, 2012 11:52 AM   in reply to Søren Langkilde Madsen
    You can maybe save yourself a lot of time IMO, by not backing up the large and complex "Preview.lrdata" folder. The Catalog database file, and the image files, are the important part.
    If you do not write LR metadata to the files, the Catalog database backup will be the only protection of your editing work; but backing it up does at least protect everything - which writing partial metadata on the files will not have done.
    However, if you do write LR metadata out to Raw - or other - files saved in DNG format, then each time you edit something, your next backup has to include all the unchanged image data - because it is all held in the same file. If you have instead used proprietary Raw files, only a small separate XMP sidecar file is written out by LR. That means there are only a few Kb to backup, for each image that has been worked on since the previous time.
    Aug 6, 2012 12:05 PM   in reply to richardplondon
    In fact it's completely pointless to back up the previews.lrdata file. Exclude it from backup.
    I'd also not go to the trouble of generating previews. Let Lightroom build them when it needs them, ie when you open a folder and view the images. With so many pictures, there's no point building the previews for everything.
    Aug 6, 2012 12:24 PM   in reply to Søren Langkilde Madsen
    Isn't it much faster to work with many small catalogues instead of one
    large one though?
    Aug 6, 2012 12:38 PM   in reply to howmanypigginnamesdoitry
    I think it depends on what "it" you want to work faster. It is my understanding that a catalog has to be extremely large (many hundreds of thousands of images) before performance becomes an issue. Since LR does not provide a means to search across catalogs finding images could be much slower with many small catalogues. Even if you felt you had to have multiple catalogs unless they were descrete (that is each image is only in one catalog) you run the risk of loosing control of editing versions.
    The common view is that one catalog is perferred to get the most out of LR. There are of course exceptions (like having one catalog per client for some kinds of professional shooters) and such things always depend on ones particular workflow. But if you feel compelled to create multiple catalogs I would ask yourself if your workflow is the best and what sacrifice are you making for what ever you are gaining -- and I would guess that speed is not what you are gaining.
    -Josh
    Aug 6, 2012 1:18 PM   in reply to Søren Langkilde Madsen
    Make sure you take a good look at smart collections. Because they're using a database query, they're much faster than Bridge when you're looking through large numbers of pictures spread across different drives. You can structure the collections more too - so a collection set might contain a mix of dumb and smart collections. But in general you seem to be heading in the right direction.
    Aug 6, 2012 1:25 PM   in reply to john beardsworth
    One of the area I emailed Adobe on in the past is help files which don't
    really give enough explanation.
    I've read up about smart collections several times now and still can't
    grasp what on earth they're all about!
    Aug 6, 2012 1:52 PM   in reply to howmanypigginnamesdoitry
    Think of them as saved queries or automatically-updating portfolios. Let's say I have a continuing need to find my best photos of cars, or weddings, or family pictures before a certain date. I just set up a smart collection with an appropriate set of criteria.
    Putting one in English, "All my pictures with the Country not UK  and Rating 3 or more and with cars in the keywords or Mercedes in the caption field (just in case I forgot to keyword a Merc rally)". So it now lists 80 pictures of cars taken when I'm travelling. Then I go outside the UK again, shoot a few cars and a few more merit 3 stars. The smart collection automatically updates and displays those extra shots. So once it's set up, it's an effortless way to get back to this portfolio of best car pics and keep updating it. That's just one hypothetical example.
    Aug 6, 2012 1:55 PM   in reply to john beardsworth
    Oh that sounds good, so you don't have to keep grouping photos or
    running a search on  a particular criteria
    Aug 6, 2012 2:05 PM   in reply to howmanypigginnamesdoitry
    I have been exploring this recently, especially as my catelog file is now 1.2Gb and growing.  I am not in the least worried about 1.5gb  or 5gb  or 10gb catelog, but I am concerned about backing this up as I exit Lightroom.  It is taking between 5 and 10 mins to complete the standard Lightroom backup. If I am under time pressure… tempting to skip..eventually disaster.
    The challenge.... make a few changes to a tiny percentage of my catelog  .. (probably a few kb of metadata in the catelog).. but now I have to backup the full catelog.
    If it is becoming a usability problem now...then it will be a bigger problem as time goes by (ie the catelog only gets bigger...)
    My current personal conclusion are  as follows:
    Keep all my images in a single catelog.  Export current project images to a working Project Catelog.  When happy that this project has matured... re-import the Project  Catelog to the Master Catelog.
    Advantages.
    I can make any no of changes in Current project mode.... backing up the catelog happens in a heart beat (relative to backing up the entire Master Catelog every time).
    All my images are in a single catelog and I am always aware of current project status.
    Current project always has a short list of folders, easier to manage and focus on work in hand... it is amazing the number of times I have clicked  through a large hierarchy of folders to get to my current project.
    This will work for me… (others milage will vary).
    Some interesting facts re my Catelog.
    Catelog Size.                                                     1.2 Gb
    No. of images                                                   Approx 60,000
    Metadata Table Size within the catelog.           515 mb
    History Table  (within the catelog)                    492 mb
    Largest 75 images of history                            Approx 253 mb with 40 images consuming 200 mb.
    Largest 200 images within the meta data table.  Approx 35 mb.
    My assumption is that brush strokes are responsible for most of the bloat factor, the price one pays for non- destructive editing.
    Aug 6, 2012 3:44 PM   in reply to john beardsworth
    Is it possible then to merge 3 catalogues into 1?
    Aug 6, 2012 4:38 PM   in reply to howmanypigginnamesdoitry
    As far as I am aware...there are no limits... but one at a time.
    I suggest you create a few small test catelogs with just a few images in each (raw, jpg, virtual)  and get familiar with what you want to achieve on a small scale.
    Aug 7, 2012 12:44 AM   in reply to howmanypigginnamesdoitry
    File > Import from Another Catalog
