Add tags to an existing PDF
Aug 6, 2012 12:27 PM
    Aug 6, 2012 12:27 PM   in reply to Community Help
    I have added tags to a pdf page and running the accessibility report still tells me that I need add tags. I have followed the directions from every angle it recommends and nothing works.
    Aug 6, 2012 1:44 PM   in reply to gatewaygraphx@gmail.com
    Without the PDF to view only general observations are possible.
    If you used Acrobat to programmatically add tags you still have to work  out of the structure tree to determine if the applied were appropriate.
    You'd have to manual check page content to determine what remained for manual application of tags or designation as an artifact.
    For those who need to or desire to provide accessible PDF the pending release of the following documents will be "must have" references.
    --| The ISO Standard for PDF/UA (ISO 14289-1:2008)
    Purchase at: http://webstore.ansi.org/RecordDetail.aspx?sku=BS+ISO+14289-1%3a2012
    --| PDF/UA-1 Technical Implementation Guide
    --| PDF/UA-1 Technical Implementation Guide: 32000-1
    (ISO 32000-1 is the current ISO Standard for PDF)
    --| Achieving WCAG 2.0 with PDF/UA
    (WCAG 2.0 for PDF is PDF/UA)
    The latter three documents are expected to be available on AIIM's web site.
    http://www.aiim.org/Research-and-Publications/standards/committees/PDF UA/App-Notes
    Be well...
    Aug 13, 2012 10:56 AM   in reply to Community Help
    Make sure that "Document is Tagged PDF" is selected in the Tags Panel.  This error will  occur if you tag the document manually.
