mike_cuesta
Create outlines rendering font poorly in Illustrator CS5, not sure what is happening
Aug 6, 2012 1:59 PM
Tags: #illustrator #problem #cs5 #bug #type_issues #font_conversion #create_outlines
Is there a reason why when I convert a font using create outlines, this is happening with Stempel Schneidler btw, it appears to add a bit of weight to the type? I've never run across this issue before. I first noticed it when I printed out the document. It all of a sudden seemed heavier compared to the font normally. The problem becomes much more pronounced at a small scale. I notice it onscreen AND when I print it. I wouldn't normally create outlines but the letterspacing is pretty tight on this and I need to make a TY ligature.
Has anyone ever experienced something like this? I need to get this resolved ASAP as the proof of this job needs to go out by Friday. Any advice would be much appreciated.
    Aug 6, 2012 2:23 PM   in reply to mike_cuesta
    Mike,
    Just to make sure: you do have Align to Pixel grid unticked, no?
    It makes a thick mess of letter shapes if ticked (or should I say thicked).
    You can see it in the Transform panel.
    Aug 6, 2012 5:32 PM   in reply to mike_cuesta
    One of the foremost reasons not to outline type. It looses all hinting that is built into the font which will usually make the font appear bolder when printed.
