piggychops
Quit InDesign and open Illustrator
Aug 5, 2012 11:13 PM
How to quit InDesign and open Illustrator using Indesign javascripting?
Here is my code:
//Quit Indesign
myDocument.close ( SaveOptions.NO );
//OPEN IN ILLUSTRATOR
#target illustrator
app.documents.add(DocumentColorSpace.CMYK, width = 1024, height = 768);
But in this code the script will perform only illustrator operations... It wont quit the indesign file...
Can any one help me...
    Aug 6, 2012 4:10 AM   in reply to piggychops
    you've got to use bridgetalk.
    #target indesign
    main();
    function main() {
              if ( app.documents.length == 0 ) { return; }
              app.activeDocument.close(SaveOptions.NO )
                        callFunction = doIlluStuff;
                        callFunction += '\rdoIlluStuff(500 , 500);';
                        btMessaging( 'illustrator', callFunction );
    function btMessaging( target, callFunction ) {
              var bt = new BridgeTalk();
              bt.target = target;
              bt.body = callFunction;
              bt.send();
    function doIlluStuff(w,h) {
             app.documents.add(DocumentColorSpace.CMYK, width = w, height = h);
    Documentation is within JavaScriptToolsGuide.
    Aug 10, 2012 3:07 AM   in reply to -hans-
    nice. and how to use bridge talk to open illustrator documents
    Aug 10, 2012 4:06 AM   in reply to bala281972
    shows also how to pass arguments ...
    but, sorry:
    is this a question or a statement¿
    Aug 10, 2012 4:17 AM   in reply to -hans-
    its a question. would like to open an eps file and export it as an svg format, i've tried illustrator.open(File ('bala.eps')); but unable to export it as svg
    Aug 10, 2012 5:25 AM   in reply to bala281972
    var myFile = "~/Desktop/Untitled-1.eps";
    var svgFile = "~/Desktop/Untitled-2.svg";
    var et = "ExportType.SVG";
    var x=","
    var bt = new BridgeTalk;
    bt.target = 'illustrator';
    bt.body = "app.open (File" + myFile.toSource() + ");";
    bt.body=bt.body+"app.activeDocument.exportFile(new File("+myFile.toSource()+")"+x.toSource()+et.toSource()+");";
    bt.onResult = function(resObj) {
    var myResult1 = resObj.body;
    $.writeln("myResult1 = " + myResult1);
    return myResult1;
    bt.send();
    this doesnt work, some minor syntax error, i couldn't sort it out
    Aug 10, 2012 6:55 AM   in reply to bala281972
    Why are you having ID send AI bridgetalk messaging to do this? I don't see your point?
    Aug 10, 2012 7:03 AM   in reply to Muppet Mark
    well, the flow is like this, indesign will export an eps file and illustrator will open that eps file and save it as svg
    Aug 10, 2012 7:09 AM   in reply to bala281972
    Well that makes sence now… although I perfer *.pdf over *.eps
    Aug 10, 2012 7:21 AM   in reply to Muppet Mark
    it doesnt matter as the final output is going to be in svg
    Aug 10, 2012 8:03 AM   in reply to bala281972
    to simplify the notation e.G. passing arguments through bridgetalk I like to do it like this:
    //store all your arguments in a array
               var myArgumentsAsArray = [File('~/Desktop/test.eps'), File('~/Desktop/Untitled-2.svg')];
                              script = myIlluScript;
    //coercing to source only this array, nothing else | ->work with calling functions
                        script += '\myIlluScript(' + myArgumentsAsArray.toSource()+ ');';
                        btMessaging( 'illustrator', script );
    function btMessaging( targetApp, script ) {
    BridgeTalk.bringToFront( 'illustrator' );
              bt.target = targetApp;
              bt.body = script;
              bt.send();
    //get the arrayparts
    function myIlluScript(aArray){
        app.open(aArray[0]);
        app.activeDocument.exportFile(aArray[1], ExportType.SVG)
    Aug 13, 2012 9:01 AM   in reply to -hans-
    doesn't work?
    Aug 13, 2012 8:21 PM   in reply to -hans-
    no, it doesnt work
    Aug 13, 2012 11:41 PM   in reply to bala281972
    no, it doesnt work
    my above posted code (which works on my machines!¿ mac / win) or your approach? ... and are you still looking for a solution?
    Have a nice day
    Aug 14, 2012 12:17 AM   in reply to -hans-
    unfortunately it doesnt work for me and still looking out for a solution. I couldnt solve it on my own as my knowledge on bridge is limited.
