DurgaCharan
Add application and document level events using javascript
Aug 6, 2012 7:12 AM
Hi All,
I need to do some validation in the preprint event of the pdf document. There are samples available using the UI and adding the script in the script dialog, but my requirement is that i need to map the 'preprint' event and event handler to the pdf document using pure javascript code without the UI. Any help would be greatly helpful. Thanks in advance.
Charan
    Aug 6, 2012 8:34 AM   in reply to DurgaCharan
    You can write a document-level function into the actions handlers using the doc.setAction() method from a folder-level script, but one folder-level script cannot create another.
    Suppose you have a folder-level function triggered by a menu item, and it has collected a reference to the active document as oDoc:
    var myScript = 'console.println("I am about to be printed and I have " + this.numPages + " pages" );';
    oDoc.setAction("WillPrint",myScript);
    Aug 7, 2012 12:51 AM   in reply to DurgaCharan
    WillPrint is fired when the document WILL print - after you press the Print button on the dialog.
    Aug 7, 2012 5:43 AM   in reply to DurgaCharan
    I'd expect
    this.setAction("WillPrint",app.alert("hi");
    to execute the app.alert at the time setAction is called, and to set an empty action. The action needs to be something that is NOT executed immediately (e.g. string).
