dave-o-design
GREP with multiple instances close to one another
Aug 6, 2012 8:14 PM
I'm having trouble with GREP outside of basics. I am using GREP to apply text styles to a paragraph. The text has been provided to me this way:
The colors starts as <ital>black<ital> and gradually progresses to <ital>white<ital>.
I'm using this: (<ital>).+(<ital>), which works fine in most circumstances. It fails on the above example, because it also italicizes "and gradually progresses to", which I don't want.
Can anyone be so kind as to point me in a direction of an explanation of what I'm doing wrong here?
Thanks in advance
    Aug 7, 2012 1:12 AM   in reply to dave-o-design
    I am unable to follow what you're doing. Can you post screen shots or simplify what you're doing?
    You mean the text comes to you with "<ital>black<ital>" in the text.
    So you want to make "black" italics? Or are you trying something else?
    Aug 7, 2012 1:31 AM   in reply to dave-o-design
    By default, GREP is Greedy and tries to match as much as text as possible. In your example
    your match <ital>.+<ital> will match everything from the first to the last code. To switch to non-greedy mode, making it match the shortest possible match, change .+ to .+? like this:
    <ital>.+?<ital>
