dfsg434534535fsf
misterios class properties
Aug 7, 2012 2:22 AM
Hello,
I'm quite new to flash development.
I'm struggling for many hours to understand the origin of several properties and their hierarchy inside as3 linked class.
The setup is:
there is a mask layer with several masked layers.
There is a movie clip for each of masked layers in libarary (some of it linked to as3):
I added layer label inside () next to name of each movie clip
Also for PhotoContainer movie clip there is external as3 class
In flash debugger i also see the following hierarchy of display objects:
Stage -> MaskArea -> photoGuideContainer (movieclip) -> photoGuide (PhotoContainer)
Stage -> MaskArea -> photoDrag (PhotoDrag) -> photoContainer (PhotoContainer)
Stage -> MaskArea -> masker (Masker)
Stage -> MaskArea -> collisionArea (Masker)
Stage -> MaskArea -> bg (movieclip)
as3 code in application classes does direct manipultion with above properties like:
maskArea = new MaskArea();
var pc:PhotoContainer = maskArea.photoDrag.photoContainer;
without ever creating/relating these display objects.
My questions are:
1. Where are all these objects come from ?
2. How the display object hierarchy is created ?
3. How photoGuide becomes an instance of PhotoContainer (see above Stage -> MaskArea -> photoGuideContainer (movieclip) -> photoGuide (PhotoContainer)) ?
Thank you.
  • kglad
    Jul 21, 2002
    Aug 7, 2012 7:13 AM   in reply to dfsg434534535fsf
    a.  you can't determine what's on stage by checking layer names.  unlock them, click a keyframe and check the highlighted on-stage objects to check their library symbol
    b.  maskArea=new MaskArea() does create a new displayobject.
    1.  all on-stage objects you see when testing are either on-stage in the ide or created with actionscript
    2. if, by hierarchy you mean depth, it is determined by the layer order (for ide created objects) and by the order objects are added to the display list (addChild) for actionscript created objects (unless addChildAt is used).
    3. photoGuide isn't an instance of PhotoContainer.  photoGuide is a child of photoGuideContainer.
  • kglad
    Jul 21, 2002
    Aug 8, 2012 7:24 AM   in reply to dfsg434534535fsf
    you're welcome.
