ID CS6 Crashes on Start
Aug 5, 2012 11:08 AM
Tags: #crash #cs6
ID routinely crashes on startup when I double click on an ID file - Windows dialog pops up stating that it is searching for a solution (never finds one).  After that goes away I can double click on the ID file again and all is well  - so it does not stop me from using ID...
This used to happen on my laptop with CS-5 but never on my desktop.  Now that I have upgraded to CS-6, it now happens on my desktop as well.  It is now irritating enough to cause me to post a question...
Both machines Windows 7 Pro - 64 bit.
Any ideas on next steps here?
    Aug 5, 2012 11:29 AM   in reply to neutronbob
    Are you using a font manager?
    Aug 5, 2012 5:34 PM   in reply to neutronbob
    The bad news is Windows doesn't produce a crash report with any really useful information, so all we can do is guess...
    Aug 6, 2012 11:07 AM   in reply to neutronbob
    Are there any similar software products on both systems? Antivirus or additional plugins perhaps?
    Running through some steps in http://helpx.adobe.com/x-productkb/global/troubleshoot-system-errors-f reezes-windows.html crosses my mind, particularly running in a simplified startup to see if anything might be trying to monitor the application when launching that first time.
    Aug 7, 2012 5:59 AM   in reply to neutronbob
    Could be Norton...
    It sounds like somthing isn't getting the chance to finish loading before ID tries to open the file.
    Aug 7, 2012 6:01 AM   in reply to Peter Spier
    And I second Scott's suggestion to try a simplified startup configuration. Run MSConfig and turn off startup programs that you don't need (which includes pretty much everything on the list, but especially the a/v and any other malware scanner). Test ID, then start adding things back until it fails, presuming it worked on first test.
