mandy17lo
Problem saving a pdf in illustrator
Aug 7, 2012 8:24 AM
Tags: #illustrator #problem #error #pdf #problem_saving_as_pdf
When I save a pdf file in Illustrator I get a sign saying "This file has no program associated to perform this action. Install the appropriate program or, if you already have it installed, create an association in the Control Panel Programs defaults ", how I fix this?
    Aug 7, 2012 8:35 AM   in reply to mandy17lo
    Exactly which options do you choose fr the PDF and exactly when does this warning pop up?
    Aug 7, 2012 9:17 AM   in reply to mandy17lo
    Is the option "open PDF after saving" checked? And do you have Acrobat installed?
    Aug 7, 2012 9:59 AM   in reply to mandy17lo
    Then your system hasn't associated Acrobat with PDF file types. So you need to do that.
    Aug 7, 2012 10:04 AM   in reply to Monika Gause
    the error message you get tells you exactly what to do...
