Dreamweaver 5.5 crashes with Mountain Lion
Jul 31, 2012 1:30 PM
Has anyone managed to get DW5.5 working on Mountain Lion?  Mine crashes on startup every time.  I 'spoke' to the live chat support who told me that Mountain Lion is not supported by Adobe.  How mad is that!
    Jul 31, 2012 5:16 PM   in reply to Edward Shephard
    What support number did you call?  I would call back and complain:
    http://www.adobe.com/products/creativesuite/faq.html#lion-os
    It's already in their FAQ that it's compatible.  Have you tried the usual steps (#12 & 4)
    http://helpx.adobe.com/dreamweaver/kb/troubleshoot-javascript-errors-d reamweaver-cs4.html
    Aug 1, 2012 8:22 PM   in reply to Edward Shephard
    I have the same problem, it crashes every time. It worked initially when I had upgraded to ML, but started crashing on startup after a few days. I have tried everything, and got it to work for 1 day, but after I started up my computer the next day it started to cash again.
    I have run disk repair, repaired permissions, updated Java, reset PRAM, uninstalled Dreamweaver, reinstalled it (set Gatekeeper to "Anywhere"), deleted prefs, deleted Dreamweaver folder from Application support/Adobe folder in library. Checked it wasn't a local account issue by trying to launch it for first time on a differnt account. None of this worked.
    I downladed the Dreamweaver 11.5.3 patch from Adobe's website, and that's when it worked for a day. But now none of the above works. I tried the Javascript errors steps SnakEyez02 suggested, but most steps require a version of Dreamweaver that launches.
    All my other CS5.5 apps work: Photoshop, Illustrator, Indesign, Flash, Fireworks, Acrobat.
    I am now at a loss. Not sure if I should spend the weekend rolling back to Lion.
    Aug 7, 2012 2:44 AM   in reply to Edward Shephard
    It works fine now after I deleted all about adobe files even those adobe air, installer, uninstaller, preferences, invisible files....etc. Then reinstall it.
    Sep 2, 2012 7:48 PM   in reply to Edward Shephard
    I found another way, you can try to remove all your preferences from your account library, or you can try a half of them, if you're lucky.
    Jan 30, 2013 1:24 PM   in reply to Edward Shephard
    I've the same issue, Dreamweaver CS 5.5 in Mountain Lion Crashes all the time when I click in any window with a form to enter any date, for example when I select properties page in the menu modify (cmnd+j), when I click in any sector to enter any data, crashes and... good bye!!!
    I read the file system info (menu apple/about mac/more info) and say this:
    Jan 30 22:04:50 xxxxxxxxxx.local Dreamweaver[6145]: The function `CGSFlushWindow' is obsolete and will be removed in an upcoming update. Unfortunately, this application, or a library it uses, is using this obsolete function, and is thereby contributing to an overall degradation of system performance. Please use `CGSFlushWindowContentRegion' instead.
    PLEASE, can you help me ADOBE????!!!!
    Feb 27, 2013 1:50 PM   in reply to pafer
    I'm getting the same message, damn you adobe
    Feb 27, 2013 2:03 PM   in reply to TenManWater
    how do I do that?
    Feb 27, 2013 3:14 PM   in reply to mizjanet
    Hi mizjanet, I solve the problem when I do the post 6.TenManWate,
    when I waste the preferences of Dreamweaver CS 5.5 and repair permissions in two faces: 1. DisckUtility and 2. ACL repair permissions
    Good Luck!
    TenManWate, THX!!!!
