traveldis2
convertTextToTable
Aug 7, 2012 5:45 AM
Hi, I want to do this function with a script: Tables can be created from existing text using the convertTextToTable method, or an empty table can be created at any insertion point in a story.
1. Select a text (story)
2. Convert to Table with a style
3. Then I want to apply some greps and styles within the same script. I already have this point working.
I guess it's very simple, but I'm new in this and I haven't found the script, can you help me?
Thank u
    Aug 7, 2012 6:10 AM   in reply to traveldis2
    the command for text objects:
    convertToTable ([columnSeparator: string][, rowSeparator: string][, numberOfColumns: number=1])
    A infoplace: http://jongware.mit.edu/idcs5.5js_html/idcs5.5js/pc_Text.html#convertT oTable
    Aug 7, 2012 10:22 AM   in reply to traveldis2
    @traveldis2 – see the following example:
    //Let's assume that we selected one single text frame only:
    var myTextFrame = app.selection[0];
    //You can access the whole story of the text frame (and all of its threadded text frames) by:
    var myStory = myTextFrame.parentStory;
    //Then we need the "texts" object of that story:
    var myTexts = myStory.texts[0];
    //We now can convert that "texts" object to a table:
    //First argument is the column separator string (in this case a "tabulator")
    //Second argument in this case is different from the first one and represents the row separator (a "return")
    //Both arguments are separated by a "comma"
    myTexts.convertToTable("\t","\r");
    That would convert the story to a table, but we have no immediate access to that table, if we want to format it, etc.pp.
    So we could shorten the above code a bit and getting access to the table by introducing a variable for our table:
    //If you want to work on with the table, you'll need a handle on it. That means a variable for the table:
    //And we could write this a little shorter:
    var myTable = app.selection[0].parentStory.texts[0].convertToTable("\t","\r");
    //The default width of the table is the width of the first container of the story.
    //All columns are devided evenly in width.
    //If you do not want that, adjust the width of all the columns in one go:
    //Example with Millimeter unit:
    myTable.columns.everyItem().width = "25 mm";
    Uwe
Bookmarked By (1)
