sachin_mak
how to rotate a square clockwise as well as anti clockwise?
Aug 3, 2012 1:22 AM
Tags: #actionscript3
hello
i know how to rotate a square in clockwise.
___________________________________________
square.addEventListener(MouseEvent.CLICK, rotate);
function rotate(Event:MouseEvent):void{
     square.rotation += 90;
Now, I want to rotate a square clockwise if MouseClick in lower part of the square. and anticlockwise if MouseClick in upperpart of the square.
    Aug 3, 2012 5:50 AM   in reply to sachin_mak
    Just subtract the rotation increment instead of adding it....
         square.rotation -= 90;
    Aug 3, 2012 6:44 AM   in reply to Ned Murphy
    Put a transparent sprite over the square that is large enough to cover the whole squares rotation and determine based on the click location versus the height of that hitarea if the rotation should be clockwise or counter-clockwise.
    Here would be a quick full code example (paste in frame 1 of a new document). I left the hitarea slightly opaque just so you could see it:
    import flash.display.Sprite;
    import flash.events.MouseEvent;
    import flash.events.Event;
    // rotation state
    var rotateClockwise:Boolean = true;
    // add sprite
    var square:Sprite = new Sprite();
    addChild(square);
    // draw square, center registration
    square.graphics.beginFill(0x000099,1);
    square.graphics.drawRect(-50,-50,100,100);
    square.graphics.endFill();
    // position a bit
    square.x = square.y = 75;
    // create "semi-transparent" hitarea
    var hitarea:Sprite = new Sprite();
    addChild(hitarea);
    // draw hitarea
    hitarea.graphics.beginFill(0x0,0.2); // set the 0.2 to 0 for full transparent
    hitarea.graphics.drawRect(0,0,150,150);
    hitarea.graphics.endFill();
    // add listener to change rotation state
    hitarea.addEventListener(MouseEvent.CLICK, changeRotation);
    // change rotation function
    function changeRotation(e:MouseEvent):void
              // top half or bottom half?
              if (e.localY < (e.target.height / 2))
                        rotateClockwise = true;
              else
                        rotateClockwise = false;
    // add enter frame to rotate clock
    addEventListener(Event.ENTER_FRAME, onEnterFrame);
    // rotate square
    function onEnterFrame(e:Event):void
              square.rotation += rotateClockwise ? 2 : -2;
    Aug 7, 2012 8:40 AM   in reply to sachin_mak
    The bottom few lines are rotating the square, the addEventListener(Event.ENTER_FRAME...) and the function below it "onEnterFrame". Just remove that code and it will stop rotating automatically.
    To have it only rotate when the mouse is clicked then add a few lines to the bottom of the function called when the hitarea is clicked "changeRotation":
         else
        square.rotation += rotateClockwise ? 90 : -90;
