Importing Quiz Questions
Aug 7, 2012 8:53 AM
I'm trying to find a way to reuse some questions in my course for inclusion in a Final Quiz, without having to reinput all of the questions.
I made a copy of my course and imported the questions I wanted for my Final Quiz. I didn't think I could use these, as they had the same interaction ID as the questions in my course. Is there a way around having to reinput questions from my course I want to include in a Final Quiz without retyping all and have my scoring work property when reporting to LMS?
Thanks very much.
Susan
  • Jorma Jennings
    Jul 5, 2007
    Aug 7, 2012 9:56 AM   in reply to SueKL
    The interaction Id can remain the same, so long as it is in a new Quiz. The Quiz ID will be unique and so the questoin responses will be tracked seperatly.
  • Jorma Jennings
    Jul 5, 2007
    Aug 7, 2012 10:01 AM   in reply to SueKL
    If you are re-importing them to the same quiz, I would just change the interaction ID to something else. That would solve the problem as well.
  • Jorma Jennings
    Jul 5, 2007
    Aug 7, 2012 10:09 AM   in reply to SueKL
    Yes, you can change them, just make sure they are unique within the quiz. They are auto generated to keep them from being repeated.
    Usually I've seen the quiz import tool create new unique interaction id's for questions. The only time I have seen the interaction ID repeated is if you use the copy/paste function to recreate the quiz slides. However, it has been a while since I used the import quiz tool.
    The cat-on-keyboard method is one trick I have seen used to keep the id's random.
