lanecollege1
Insert Text in a PDF Document
Aug 7, 2012 10:25 AM
I am trying to edit text (insert text) in a pdf document using Adobe 9 Pro.  When I click on Advanced Editing, touch up text tool.  I select a box around the text and begin to type, nothing appears the cursor moves but nothing is typed.  I need immediate help .
    Aug 7, 2012 10:27 AM   in reply to lanecollege1
    Check the font colour. Check the font, see if it works if you select a different font.
    See if it works if you type the same word that was already there (that will tell us something).
    Aug 7, 2012 11:39 AM   in reply to lanecollege1
    Editing text and Adding text require different tools.
    The Touch up text tool would be used to modify; add, modify or delete within a line of existing text.
    To add text to an open area, the Typewriter tool would be necessary.
    Don't expect full editing abilities.
    Aug 7, 2012 11:54 AM   in reply to Daniel Flavin
    Actually, I would not use the typewriter tool for that. It adds an annotation, and that may not be what is needed.
    Personally, I'd add text with the Touch-up Tool. Ctrl+click will allow it.
