Locked
Error trying stream to iOS (HLS)
Guest
Aug 07, 2012 Aug 07, 2012
I'm trying to stream:
FMS URL: rtmp://189.1.162.243/livepkgr
Stream: livestream?adbe-live-event=liveevent
[you can try to connect too]
But I can not to deliver as HTTP, the error log show:
2012-08-0715:37:564060(e)2611178Error from libf4f.dll: Track not found..-
905
Deleted User
This could happen if audio/video is received after the first fragment has been created. To ensure this doesn't happen audio and video should start at the same time.
What I suggest is that you clear out the streams folder under livepkgr and the .stream file from under livepkgr/events/_definst_/liveevent, restart your server and then start your audio-video publish at the same time. Are you using FMLE to publish the stream?
If that doesn't help, you can try increasing the fragment duration in the
Adobe Employee ,
Guest
If that doesn't help, you can try increasing the fragment duration in the Event.xml.
Let me know if that works.
Apurva
Guest
Aug 08, 2012 Aug 08, 2012
That's it! Solved. Now that's working. Thank you!
