Steeljaw65
PSE 10 Organizer layout changes won't stay
Aug 6, 2012 6:28 PM
Upgraded from PSE9 to PSE 10.  Win 7 OS.  Setting the Organizer to display in Folder view, and then adjusting the Photo bin size larger (to the left) does not "take."  It will remain as I set it as long as I remain in that session.  If I close the program and then restart, the Organizer layout has reverted to the default layout with a small Photo bin.  This was automatic in Version 9 and it saved it where I put it.  How do I fix this irritating problem please?
    Aug 6, 2012 7:36 PM   in reply to Steeljaw65
    The general suggestion when PSE starts acting goofy is to reset the Preferences.  For the Organizer, rename this file to "oldpsa.prf":
    "C:\Users\<username>\AppData\Roaming\Adobe\Elements Organizer\10.0\Organizer\psa.prf"
    That is a hidden directory, so you'll have to temporarily allow viewing hidden files in your Folder Options.
    Obviously, you'll have to manually change all your Organizer's settings back to what you want.
    Ken
    Aug 7, 2012 9:59 AM   in reply to Steeljaw65
    I am not sure de-installing and reinstalling will help. If you want a clean desinstall, see:
    http://www.johnrellis.com/psedbtool/photoshop-elements-faq.htm#_Removi ng_all_traces
    To save the layout, I use one of the scripts in Elements+, an affordable add-on which has a lot of missing features in Elements.
    http://simplephotoshop.com/elementsplus/
    Aug 7, 2012 12:20 PM   in reply to Steeljaw65
    I agree with Michel that re-installing PSE probably won't help, but here is the Adobe documentation for manually removing PSE9, just change the references to "10.0":
    http://helpx.adobe.com/photoshop-elements/kb/manually-remove-photoshop -elements-9.html
    Are you running multiple monitors?
    Ken
    Aug 7, 2012 12:22 PM   in reply to MichelBParis
    Michel,
    I don't think that E+ targets the Organizer.
    Ken
