Grenadianexpat
When PE9 imports AVI's it "conforms" them
Aug 6, 2012 6:59 PM
Tags: #windows_7 #premiere_elements_9
Unfortunately quite often it hangs at some point in the process. It could be 7% or for another file 25% etc. There is virtually no CPU usage, and Physical memory is around 50%, so it is not being overworked at the point of lock up. The only way to get out of the mess is the 3 finger salute and opt to close.
I cannot see a consistent reason why it does it, as the media being imported can be small eg 125MB and freeze, or be 1.5Gb and conform with no issues.
All the files have been created by the same program Audials one 9 via screen recording, and play equally well prior to attempting to import.
Perhaps it is not connected, but PE9 has an annoying habit of opening with previous information, either from Photoshop, or previous use in elements, even when one has selected "new project".
I have a Q9300Duel Quad processor, a Geforce GTS450 Graphics Card, and regrettably only 4GB of memory I am using Win7 64 service pack 1.
The hang information is as below.
Problem signature:
  Problem Event Name:    AppHangB1
  Application Name:    Adobe Premiere Elements.exe
  Application Version:    9.0.0.0
  Application Timestamp:    4d01cdbb
  Hang Signature:    f603
  Hang Type:    1
  OS Version:    6.1.7601.2.1.0.768.3
  Locale ID:    2057
  Additional Hang Signature 1:    f603542970df1267bf2d719a3a1fae80
  Additional Hang Signature 2:    1a6c
  Additional Hang Signature 3:    1a6cc8da3a788ea0dc354c10da3defd6
  Additional Hang Signature 4:    13fd
  Additional Hang Signature 5:    13fd23ebf2621d00bf5729ebd2c40602
  Additional Hang Signature 6:    aede
  Additional Hang Signature 7:    aedeee27db136acd3fea4d61f5c4299e
    Aug 7, 2012 4:53 AM   in reply to Grenadianexpat
    Premiere Elements will not likely work with video created by another program unless it is created to certain specs. It sounds as though your Audials program may be using a codec the program can't read.
    Open one of your AVIs in a program like G-Spot or Media Info and post the specs here.
    We're most interested in your frame rate, resolution and, above all, your audio and video codecs. If the programs come back with "codec undetermined" it's pretty likely you're not going to be able to edit that video in Premiere Elements.
    Aug 7, 2012 2:33 PM   in reply to Grenadianexpat
    Xvid/Divx are output files, not meant to be edited (variations of the MPEG4 codec, often used for Internet streaming video) so, they mostly do NOT edit well (if at all) in any flavor of Premiere
    To edit a divx file, start at http://www.divx.com/
    To edit an xvid file, start at http://www.xvid.com/
    Aug 9, 2012 4:48 AM   in reply to Grenadianexpat
    Glad to hear we werre helpful, expat.
    If you appreciated our response, please indicate it on this forum. Adobe uses this feedback to evaluate how well these forums are working.
