How can I rotate a PDF document when viewing in adobe reader?
Aug 7, 2012 10:40 AM
Tags: #pdf #adobe_reader
How can I rotate a PDF document when iewing in adobe reader?
    Aug 7, 2012 10:57 AM   in reply to nickpatsalos
    This isn't possible unfortunately. You need to use a desktop program such as Acrobat to do this.
    Aug 7, 2012 10:58 AM   in reply to nickpatsalos
    If you're on an iPad or iPhone, when you rotate your device, the PDF should rotate. It's possible to set a preference to lock the device to keep the rotation from happening, so check that setting.
    Aug 7, 2012 10:59 AM   in reply to Steve Werner
    Alec,
    I read the request differently. I thought Nick was asking about the viewing of a PDF document. But he wasn't clear.
    Aug 7, 2012 1:13 PM   in reply to nickpatsalos
    I have a new iPad (iPad 3). If you look just above the volume toggle on the side of the iPad, there is a "lock orientation" control. When turned on, you cannot rotate your PDF (or any other file).
    Aug 7, 2012 2:05 PM   in reply to nickpatsalos
    That hardware button can actually be toggled to work either as a mute button, or a lock orientation button. This can be edited at the settings screen.
