Illustrator crashes when trying to export to png
Jul 31, 2012 11:36 AM
Tags: #illustrator #error #mac #osx #crash #png #cs6 #not_responding #export_to_png
My issue is pretty straightforward, I cannot export to PNG unless I trash the Illustrator preferences (located in: user/Library/Preferences/Adobe Illustrator CS6 Settings/en_US/) BEFORE I start Illustrator. As soon as I close Illustrator, I must delete those preferences again the next time I start up the program or I won't be able to export a file.
- I recently upgraded to Mountain Lion, but I was having the same issues in Lion
- I have uninstalled the whole CS6 Creative Suite and reinstalled (literally deleting every single Adobe file in the Library folder) still the same issue
- It seems to only be PNG files that I can't export to. If I try and make it a JPG it will export (I do commonly need to export with transparency so JPGs won't work for many things I need to export)
I can't think of anything else to do. Thoughts?
    Jul 31, 2012 11:50 AM   in reply to dim7chord
    Check the permissions on the Preferences/Adobe Illustrator CS6 Settings folder as well as the Library/Application Support/Adobe/Adobe Illustrator CS6/en_US. Make sure that you have Read/Write for all the items within those folders.
    Jul 31, 2012 12:03 PM   in reply to dim7chord
    For just you or for Everyone?
    Also does it do the same if you use Save For Web&Devices?
    Jul 31, 2012 12:07 PM   in reply to dim7chord
    dim7chord wrote:
    .....literally deleting every single Adobe file in the Library folder......
    So you did that manually?
    Did you simply run the unistaller? There are files you may have missed manually.
    Jul 31, 2012 12:20 PM   in reply to dim7chord
    If you boot to Safe Mode (hold down the Shift key while booting the machine), can you export then?
    Jul 31, 2012 12:28 PM   in reply to dim7chord
    dim7chord,
    While you are in the scathing mood, you may try using the Cleaner Tool between uninstalling and reinstalling.
    http://www.adobe.com/support/contact/cscleanertool.html
    That should be the safe and simple way.
    I wonder whether this could be one of the cases of disturbance from other applications. If so, (some of) the usual suspects are:
    Quicktime/iTunes,
    Quicken (Widget),
    Entourage,
    Google Earth,
    Zune,
    Some Firefox Add-ons,
    Spotlight (shortcuts),
    Fetch,
    Hulu,
    Cocktail,
    Cinch,
    RightZoom,
    Synergy,
    FontExplorer.
    Aug 8, 2012 10:39 AM   in reply to dim7chord
    I've been having this exact same problem with CS5 on Mountain Lion. Anything that rasterizes the artwork causes it to hang. Export (PNG), Save for Web, Filters like Drop Shadow or Gaussian Blur (even when just checking the preview box).
    If I delete the preferences it works fine for one run of the app, then it happens again.
    Temporary Fix (kinda lame)
    1. Edit the contents of the Preferences File in a text editor and remove everything (0 bytes, blank file).
    2. Open the Info box and lock the file.
    http://dl.dropbox.com/u/2176334/Screenshots/qyvd-4mvl36l.png
    Your preferences will stop saving, and the issue will go away, but now non of your preferences will save, you'll be reset every time you open the app.
    I will continue to diagnose and see if I can narrow down the area of the config that is breaking things.
    I would love a solution for this.
    Message was edited by: VACUBOMB
    Aug 7, 2012 4:07 PM   in reply to dim7chord
    dim7chord wrote:
    "That was what I did to hopefully fix the issue. "
    Did you fix it?
    Aug 15, 2012 8:21 AM   in reply to VACUBOMB
    I would also suggest testing to see if the behavior occurs when logged in as a different newly created user with administrative rights. Issue could be related to permissions beyond just the preferences file.
    Here are instructions if needed
    10.6 http://support.apple.com/kb/PH6651
    10.7 http://support.apple.com/kb/PH4600
    10.8 http://support.apple.com/kb/PH11468
    -Dave
    May 30, 2013 10:29 AM   in reply to VACUBOMB
    specifically it's the line defining AIResolutionIndependentEffects.cfg
    this config must be destroying older macs perhaps.
    but this line alone is responsible.
    May 30, 2013 10:55 AM   in reply to drewcovi
    also worth noting there's little point updating the file as it's rewritten on quit. but perhaps you can save preferences and lock them in (excluding the line above) using VACUBOMB's trick
    Jun 15, 2013 6:16 PM   in reply to dim7chord
    Same issue for me. Macbook OS X 10.8.4
