Unable to activate via TMG
Aug 7, 2012 5:48 PM
Tags: #error #authorization #failed #activation #digital_editions #adobe_digital_editions
I am unable to activate Digital Editions on our school network. We need to use this software, as the library is now doing ebook loans.
I am able to go to http://adeactivate.adobe.com/
When I open up Digital Editions it asks for my username and password (for the Microsoft TMG proxy) but fails over and over and I receive the E_ADEPT_IO ActivationServiceInfo Error%20#2032
I do not see anything in the TMG logs when I open Digital Editions and enter in the password.
I have also tested with the Firewall on the desktops disabled.
    Aug 10, 2012 6:45 AM   in reply to WestminsterSA
    I read the thread, and I'm puzzled.
    First, ADE was never intended to be used via a network.  It's just a
    library management system designed to be used by one user at a time.  If
    the Adobe rep tried to get it running on a network, he probably wasn't
    trained in ADE.
    Next, I think you're confused - and probably others are as well.  ADE works
    with the implementation of Digital Rights Management (DRM) that comes from
    Adobe Content Server - which is entirely separate software.  And that may
    be why you think you have to use ADE. But that's not true.  ADE is not the
    only implementation of DRM.
    Digital rights have been incorporated into several other software systems
    that are used commercially (in contrast to ADE), and some of those systems
    are being used for multiple users in a situation like yours.  The most
    obvious one is Overdrive.  It's used by a large number of libraries and
    publication houses to distribute and manage multiple sites and multiple
    users.  If you're thinking of 'distributing' textbooks to students, that's
    a parallel to libraries loaning ebooks to patrons, and Overdrive will work
    just fine for that.
    I'm sure that this isn't the answer you were looking for, but....
    Aug 12, 2012 11:37 PM   in reply to WestminsterSA
    Thanks for clarifying the environment.  That helps.
    But, as far as the use of ADE is concerned, the website that you've
    referenced states that they use Digital Rights Management.  I didn't go far
    into the site, but you should not make the assumption that you must use
    Digital Editions, perhaps because it's from the same vendor as the DRM
    protection software.  You could use Calibre, Overdrive, Bluefire Reader (or
    Apple software) and achieve the same results.  .ascm files work with all of
    those products (but Apple has implemented DRM a bit differently).
    I'm not an Adobe employee, nor did I work on the design of the software.
    However, I have worked in programming extensively during my 40 year career,
    and I've been emmeshed in similar design situations.  The blending of
    distribution from a central point and software that's designed to be
    downloaded individually from the vendor's site doesn't work well - and
    that's why I commented on the 'network' side of things.  The software
    coding gets difficult if access to the Internet is controlled by a gateway,
    which I think is what you're saying.  It's not that Adobe has a 'bad
    design' - it's that Adobe did not design its software to be downloaded in
    your environment.
    I understand the need to try to manage access to the Internet in an
    environment like yours.  In my experience, resolving this conundrum
    involves figuring out whether you will permit the user to download
    according to the software's expectations or not.  The alternative that
    might work is to have the users download the software directly from
    whichever product vendor you select.  I don't think you'll have this issue
    if you use Overdrive or Calibre.  I can't speak for Bluefire Reader.
    Nov 20, 2012 2:46 PM   in reply to WestminsterSA
    Hi WestminsterSA, I have the same problem. Can you tell me please How should I configure my proxy server? Thanks in advanced
    Nov 20, 2012 3:31 PM   in reply to Luis.Portocarrero.Pinto
    I answered WestminsterSA concerning downloading via his school's network.
    I missed a part of the answer, however, and he repeated part of the
    question:
    "If Adobe did not design it's software to work with a local computer system
    wide proxy.... why does it? It uses the system proxy but then fails at
    authentication. This IS bad software design."
    He fails to understand that his school proxy settings - anonymous - are not
    connected in any way to the way ADE is coded.  It was never designed as
    anything other than a 1:1 software system: the user connects directly with
    Adobe.  Your network is passing stuff up the line, but it's failing at the
    network's authentication, not at ADE's.  My comments about use in a
    networked environment are still valid.  And that's not 'bad software
    design" at all.
    To both of you: the suggestions I have for server configuration are made in
    a vacuum, because I don't know anything about your IT environment or who
    controls what portions of it.  Given that ADE wants to connect directly
    with Adobe to be installed, AND ADE anticipates a direct connection with
    the ebook sources, I'm not sure that you can do anything at all with the
    servers.  However, if your servers can be configured to permit ADE to
    connect directly with Adobe, or vice versa, then you 'may' be able to get
    ADE to run effectively.  The prototype is the WIndows 7 firewall, which
    acts as a 'network' front end.
    In the US, schools libraries and universities in general do not use ADE for
    students or patrons.  They use more robust, multi-user systems like
    Overdrive (not Calibre - they do not have a DRM module).  You do not HAVE
    to run ADE in order to get DRM-enabled material.  What's tripping you up -
    and many more than just you two - is the fact that Adobe's Content Server
    Manager CSM) is the core of DRM processing in several of the epublication
    management systems.  Because CSM is in widespread use, AND because Digital
    Editions is able to interact with it by design (Adobe product to Adobe
    product), many, many sources for ebooks combine the two, and tell you that
    you 'must' use ADE.  Overdrive would take exception to that.
    My overall suggestion is to sit down with the IT department and hash this
    out IF lots of the students are going to use or are using ebooks for
    classes and research.  It sounds like neither of your institututions has
    thought this out thoroughly.  Yes, that's an oversimplification, and may
    not be possible.  But you should try!
    On Tue, Nov 20, 2012 at 3:46 PM, Luis.Portocarrero.Pinto <
    Nov 20, 2012 7:50 PM   in reply to WestminsterSA
    I've been working with software for over 30 years.  I understand the way
    proxying works from the lowest level.  Do not lecture me on how you think
    it should work.
    ADE does not supply credentials because it does not know that it's
    operating in a proxy environment.  The proxy server doesn't tell it that it
    is - and it wouldn't matter anyway, because ADE's 'bad' design is not
    intended to operate in that environment.  Period.
    Nov 20, 2012 11:05 PM   in reply to WestminsterSA
    Sorry.  The proxy server is asking for those credentials, not ADE.
    We're back to the fact that ADE is not intended for use in a network.
