Flash says already installed but it is not
Aug 5, 2012 11:52 AM
As stated.  I was having problems viewing some videos and figured it may be a problem with flash.  I had the 32bit version but I am running windows 7 64bit.  So I uninstalled adobe flash from the computer using the control panel, then rebooted.  Now When I attempt to download the Flash 64bit from the website (using IE 9, 64bit) the program downloads, and once it begins to say installing it stops and I receive a message saying A newer version of adobe flash is already installed.  But it is not installed and does not exist anywhere I can find on my computer.
thanks for any help
    Aug 5, 2012 12:30 PM   in reply to quietstep
    I am having the same exact issue under the same exact circumstances. Someone please help.
    Aug 5, 2012 12:50 PM   in reply to Fiat500Sport
    I also am having the same problem.  Vista 32 bit.  All was fine yesterday, now lots of problems.  There has to be fix for this.
    Aug 5, 2012 12:56 PM   in reply to quietstep
    Same problem here! I have tried uninstalling all adobe products and rebooting, then reinstalling and the others did fine but I keep getting this same message on Flash Player. Very frustrating!
    Aug 5, 2012 12:57 PM   in reply to quietstep
    I can't upload with flash uploader... or view flash videos. Same at "quietstp" stated. I use this comp for work and am dead in the water wo these things working properly.
    The program downloads, and once it begins to say installing it stops and I receive a message saying A newer version of adobe flash is already installed.  But it is not installed and does not exist anywhere I can find on my computer.
    thanks for any help
    Aug 5, 2012 12:59 PM   in reply to quietstep
    This just started 3 days ago
    Aug 5, 2012 1:59 PM   in reply to Fiat500Sport
    I am having the same problem - it started a few days ago - now I can't install Flash Player no matter what I've tried.
    Aug 5, 2012 2:50 PM   in reply to quietstep
    Ok Adobe... feel free to chime in... the problem is with both I.E. and Firefox 64 and 32 bit. I have windows7 64bit OS but the problem does not seem to be limited my OS. I have tired everything... uninstall... reinstall update... and still the issue exists.   I show that flash player is installed but both browsers tells me that it needs to be updated. When I try to update it tells me I already have the latest version... and cancels the update. There must be some issue beyond my end because there is nothing more I can do from here.
    Aug 5, 2012 6:00 PM   in reply to quietstep
    Weird - so many users with the same problem!
    I am going to test this now; uninstall, then reinstall Flash Player on my Win7 x64 system...
    Aug 5, 2012 6:10 PM   in reply to quietstep
    I am unable to reproduce that; I have just uninstalled / reinstalled three times - no problem whatsoever.
    Here is what I did; try doing the same:
    If you still get any error messages, please post a screenshot of it.
    Aug 5, 2012 6:49 PM   in reply to Pat Willener
    Ok... followed your instructions & got I.E. to work properly. But Firefox is still the same
    Aug 5, 2012 7:41 PM   in reply to quietstep
    What is your display adapter, device driver version & date? (See http://forums.adobe.com/thread/945765)
    Aug 5, 2012 7:42 PM   in reply to Fiat500Sport
    Can you post a screenshot of that?
    Aug 7, 2012 9:41 AM   in reply to Pat Willener
    Simplest and quickest and most CORRUPT solution is to run FLASH from Chrome.   Until this issue is correct, that seems the way to get the job done.
    It appears the issue is that Chrome is blocking the use of FLASH with any other brower because of some code embedded in the version of FLASH downloaded as an "update",  if the user did not UNCHECK the optional Chrome download that was available at the same time.    To run FLASH without Chrome you will likely have to uninstall both programs and reinstall the offered FLASH version making sure that Chrome is not downloaded at the same time.  If that does not work, it is probably simplest to go back to the next earliest version and download that.
    It almost appears as if Adobe is in bed with Chrome and trying to help it further control the market .... this is a shame, because good products should need no help from clandestine "marketing" tricks.
    Aug 7, 2012 6:02 PM   in reply to raynorshines
    What is your obsession with Chrome?  This topic is about Firefox.
    Aug 7, 2012 6:23 PM   in reply to Pat Willener
    Obsession, observation maybe.... the discussion is about problems with FLASH updates and how this are not working.  I think the issue is common for those using  browsers other than, dare it say it... no I won't ... you know the one owned by Google
    Aug 9, 2012 3:35 PM   in reply to Pat Willener
    I will update display drivers... and attempt the process again and see
    Aug 9, 2012 5:58 PM   in reply to Pat Willener
    Side by side screen shot  <I.E.   >Firefox after followed your instructions.
    I have followed your instruction 3 times an still end up the same. I.E. works but Firefox still tells me I need to update. When I follow the prompt to update... it tells me I already have a newer version installed
    I uninstalled with listed uninstaller, deleted the files in the two directorys you listed, and downloaded both the offline .exe for each.... and installed each just as you instructed. I closed both I.E. and Firefox. then ran the offline installers.
    Here is the funny thing... when I install Adobe Flash that is for Firefox... a window opens in I.E. saying your installation was a success but does not work in Ff.
    Aug 9, 2012 6:10 PM   in reply to Fiat500Sport
    Can you post the FlashInstall.log file from both install folders?
    Aug 9, 2012 6:18 PM   in reply to Pat Willener
    =O====== M/11.3.300.268 2012-08-10+00-11-59.042 ========
    0000 [I] 00000010 "C:\Users\Tina\AppData\Local\Temp\install_flash_player_ax.exe" -install -iv 8 -au 0
    0001 [W] 00001036 Software\Macromedia\FlashPlayer\SafeVersions/11.0 2
    0002 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0003 [I] 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
    0004 [I] 00000011 1
    0005 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
    0006 [I] 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_3_300_268.ocx
    0007 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_3_300_268_ActiveX.e xe
    0008 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_3_300_268_ActiveX.d ll
    0009 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
    0010 [I] 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
    0011 [I] 00000012
    =X====== M/11.3.300.268 2012-08-10+00-12-02.973 ========
    =O====== M/11.3.300.268 2012-08-10+00-16-09.999 ========
    0000 [I] 00000010 "C:\Users\Tina\AppData\Local\Temp\install_flash_player.exe" -install -iv 8 -au 0
    0001 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/Version 2
    0002 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
    0004 [I] 00000011 1
    0005 [W] 00001037 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
    0006 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
    0007 [W] 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
    0008 [W] 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
    0009 [W] 00001036 Software\Opera Software/Last CommandLine 2
    0010 [W] 00001036 Software\Opera Software/Last CommandLine 2
    0011 [W] 00001036 Software\Opera Software/Plugin Path 2
    0012 [W] 00001036 Software\Opera Software/Plugin Path 2
    0013 [I] 00000014 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_11_3_300_268.dll
    0014 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_3_300_268_Plugin.ex e
    0015 [I] 00000017 C:\Windows\SysWOW64\Macromed\Flash
    0016 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
    0017 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 183
    0018 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerApp.exe 183
    0019 [I] 00000022 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_11_3_300_268.exe
    0020 [I] 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
    0021 [W] 00001106
    0022 [W] 00001106
    0023 [W] 00001024 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe 183
    0024 [I] 00000012
    =X====== M/11.3.300.268 2012-08-10+00-16-14.604 ========
    2012-8-10+0-25-33.848 [error] 1226 1062
    =O====== M/11.3.300.270 2012-08-10+00-25-30.956 ========
    0000 [I] 00000010 FlashPlayerInstaller.exe -install -iv 9
    0001 [I] 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
    0002 [I] 00000011 1
    0003 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_3_300_268.ocx 5
    0004 [I] 00000018
    0005 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_3_300_268.ocx 5
    0006 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_3_300_268_ActiveX.d ll 5
    0007 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_3_300_268_ActiveX.e xe 5
    0008 [I] 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_3_300_270.ocx
    0009 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_3_300_270_ActiveX.e xe
    0010 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_3_300_270_ActiveX.d ll
    0011 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
    0012 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 183
    0013 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerApp.exe 183
    0014 [I] 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
    0015 [W] 00001106
    0016 [W] 00001106
    0017 [W] 00001024 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe 183
    0018 [I] 00000012
    =X====== M/11.3.300.270 2012-08-10+00-25-35.800 ========
    =O====== M/11.3.300.268 2012-08-10+01-01-47.840 ========
    0002 [I] 00000011 1
    0003 [W] 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
    0004 [W] 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
    0005 [W] 00001036 Software\Opera Software/Last CommandLine 2
    0006 [W] 00001036 Software\Opera Software/Last CommandLine 2
    0007 [W] 00001036 Software\Opera Software/Plugin Path 2
    0008 [W] 00001036 Software\Opera Software/Plugin Path 2
    0009 [I] 00000014 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_11_3_300_268.dll
    0010 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_3_300_268_Plugin.ex e
    0011 [I] 00000017 C:\Windows\SysWOW64\Macromed\Flash
    0012 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
    0013 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 183
    0014 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerApp.exe 183
    0015 [I] 00000022 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_11_3_300_268.exe
    0016 [I] 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
    0017 [W] 00001106
    0018 [W] 00001106
    0019 [W] 00001024 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe 183
    0020 [I] 00000012
    =X====== M/11.3.300.268 2012-08-10+01-01-52.133 ========
    Aug 9, 2012 6:20 PM   in reply to Pat Willener
    0004 [W] 00001037 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
    0005 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
    0006 [W] 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
    0007 [W] 00001036 Software\Mozilla\MaintenanceService\extensions/Plugins 2
    0008 [W] 00001036 Software\Opera Software/Last CommandLine 2
    0010 [W] 00001036 Software\Opera Software/Plugin Path 2
    0012 [I] 00000014 C:\Windows\system32\Macromed\Flash\NPSWF64_11_3_300_268.dll
    0013 [I] 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_3_300_268_Plugin.ex e
    0014 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
    0015 [I] 00000012
    =X====== M/11.3.300.268 2012-08-10+00-16-11.214 ========
    =O====== M/11.3.300.270 2012-08-10+00-25-31.571 ========
    0000 [I] 00000010 "C:\Windows\TEMP\{47A456C8-3B4B-48B3-A504-D323FC78356B}\InstallFlashP layer.exe" -install -skipARPEntry -iv 9 -au 4294967295
    0002 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
    0003 [W] 00001015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_3_300_268_ActiveX.e xe 5
    0004 [I] 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_3_300_270.ocx
    0005 [I] 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_3_300_270_ActiveX.e xe
    0006 [I] 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_3_300_270_ActiveX.d ll
    0007 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
    0008 [I] 00000012
    =X====== M/11.3.300.270 2012-08-10+00-25-32.795 ========
    =O====== M/11.3.300.268 2012-08-10+01-01-48.720 ========
    0000 [I] 00000010 "C:\Users\Tina\AppData\Local\Temp\{DB74FCA5-0C1F-4E2F-B9B1-910C632B12 BF}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 0
    0002 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
    0004 [W] 00001036 Software\Mozilla\MaintenanceService\extensions/Plugins 2
    0009 [I] 00000014 C:\Windows\system32\Macromed\Flash\NPSWF64_11_3_300_268.dll
    0010 [I] 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_3_300_268_Plugin.ex e
    0012 [I] 00000012
    =X====== M/11.3.300.268 2012-08-10+01-01-49.469 ========
    Aug 9, 2012 6:22 PM   in reply to Fiat500Sport
    Looks good to me...
    In Firefox, type about:plugins in the address bar; can you see Shockwave Flash ?
    Aug 9, 2012 6:26 PM   in reply to Pat Willener
    Aug 9, 2012 6:43 PM   in reply to Pat Willener
    and
    Aug 9, 2012 6:57 PM   in reply to Fiat500Sport
    Thank you; I see that you have RealPlayer installed, which is known to have a conflict with Flash Player 11.x
    Can you try to disable Real Player and see if FP works?
    Or before that, try restarting Firefox in Safe Mode (from the Help menu).
    P.S. I have to go now; I will not be able to reply for a few hours.
    Aug 9, 2012 6:58 PM   in reply to Pat Willener
    Aug 9, 2012 7:06 PM   in reply to Pat Willener
    OK.... you nailed it. I disabled everything named REAL... and it works. Ty for taking the time to help me Pat
    Aug 9, 2012 7:59 PM   in reply to Fiat500Sport
    Great!  Hopefully that conflict will get resolved in a future release.
    Aug 10, 2012 2:51 PM   in reply to Pat Willener
    My problem started when I changed internet servers two days ago. My existing FP disappeared and when I tried to install it again, it says: A newer version is already installed. I have Adode Reader and Adobe Air, but not Adobe Flash Player. I uninstalled Chrome and Real Player, but still get the same message. I have IE9, Windows Vista, 32 bit. I'm curious about the rash of FP problems in the last few days and why mine would stop working and disappear from the Programs Control Panel.
    Aug 10, 2012 3:40 PM   in reply to Carol Luce
    Eureka! I tried Pat's instructions and it worked! However, I think I have the version 10., rather than the 11. But whatever works. Thank you so much, Pat.
    Aug 11, 2012 6:26 AM   in reply to Pat Willener
    This worked for me. Thanks!
    Oct 12, 2012 8:44 PM   in reply to raynorshines
    I also wasn't able to install or update Adobe Flash with Firefox or IE.  I also wasn't able to watch video's in either browser.  Tried several things with no luck until I read your post.  I had Google Chrome on my computer so I opened it and tried to watch a video and it worked just fine.  Then I uninstalled Google Chrome and now Adobe Flash and videos work in both Firefox and IE.  Thank you!
    Oct 26, 2012 6:35 AM   in reply to szmelp
    I checked with adobe:plugins and I don't have anything "REAL" on my computer. I removed the other versions of flash from "Add/Remove Programs" and I'm still getting the error message "There is a higher version exist on the system , Can't install".
    Oct 26, 2012 6:57 AM   in reply to Moes12
    In addition, I just uninstalled google chrome and I still have the same error message.
  • Chris Campbell
    May 4, 2010
    Oct 26, 2012 4:02 PM   in reply to Moes12
    @Moes12 - Please try running the stand alone Flash Player uninstaller found here (ir's required if you want to go back to a previous version) - http://download.macromedia.com/get/flashplayer/current/support/uninsta ll_flash_player.exe
    How do I revert to a previous version of Flash Player?
    Oct 26, 2012 10:12 PM   in reply to Chris Campbell
    Hi Chris,
    When I click on the link you gave me it tells me to close Internet Explorer. IE is the only thing that I have on my computer now as I removed Chrome to see if that would help with opening my swf file. Thus fare it hasnt. Thank you for the help.
    Ted
    Oct 28, 2012 10:38 PM   in reply to Moes12
    Ted,
    For running the file that Chris provided, you need to close Internet Explorer. Could you please try run it again and see?
    Sunil
