Hide indesign instance (Hide running application)
Aug 7, 2012 4:22 AM
Hi
I am creating indesign instance using this code
INDESIGN::_Application oApplication;
oApplication.CreateDispatch(L"InDesign.Application") ==0);
Indesign application start successfully.
I want to hide the application means when i create instance then application should not visible
and run in backside.
for example
Dim objWord As Word.Application
Dim objDoc As Word.Document
Set objWord = New Word.Application
objWord.Visible = FALSE;
There is a Application property visible to set application visible.
i am using indesign.h and indesign.cpp file created from .tlb file of CS5(7.5).
In my .h and .cpp file there is no application visible function or application class property
    Aug 8, 2012 1:58 AM   in reply to Bill joy
    The InDesign appliction's visible property is read only. Try to use minimize method like so:
    app.documents[0].layoutWindows[0].minimize(); // this is JS, in VB it will be similar
