I would like it the Sass in the Dreamweaver to be useful integrating. (extension(*.scss) and language support) [Im working PC]
Can somebody help me?
Not aware of an extension for this, but here's a blog post by Greg Rewis with info about how to add support for SASS in Dreamweaver:
http://blog.assortedgarbage.com/2012/03/using-dreamweaver-with-sass-and-less/
Thank You!
Can I ask you for some assistance.
I tried to follow the assortedgarbage tutorial, but I was only able to find the files listed in the applications folder, and nothing in the ~username/Library/Application Support/Adobe/Dreamweaver CS5.5/en_us/Configuration or any other folder that represents Dreamweaver, as this one specifically states CS5.5.
I did modify the files in the Application directory to match the tutorial, and I even added .scss, .sass., .less files to the accepted file types in preferences but no matter what I seem to do I get no color coding....
Do you know if it has anything to do with it being cs6, or some other variable option?
Thank you, any help is appreciated.
Same issue here - no code hinting. Have gone over everthing 3 times
Admin mode:
MMDocumentTypes.xml, Extension.txt, User Extensions.txt
Intalled successfully adamcoulombe / dw-compass-codehints
According to DW is shows up properly however no change.
Any help w/ this? Is it a CS6 problem? Other?
Moonshot0087,
I know on my end I stumbled across the solution and I do hope this works for you as well.
If you are working in Mountain Lion with cs6 I can tell you I couldn't find one of the sets of files because they were in a HIDDEN /library folder in my user directory.
If this is the problem that you are having, make sure first to go to terminal and turn on hidden files (copy this into terminal):
defaults write com.apple.finder AppleShowAllFiles -bool true
Then hold "Alt/Option" and right click "Finder" then click "Relaunch" in the pop up menu.
From there you will be able to find the /Users/"USERNAME"/Library/Application Support/Adobe/Dreamweaver CS6/en_US/Configuration/extensions.txt and /Users/"USERNAME"/Library/Application Support/Adobe/Dreamweaver CS6/en_US/Configuration/DocumentTypes/MMDocumentTypes.xml.
Once you edit those files restart Dreamweaver and everything should work just as expected.
When I edit a extension.txt file in cs6 then save its showing error access denied? Please resolve my issue.
Have a look at Pleysier Web Solutions
Built an extension to do this:
https://github.com/adamcoulombe/dw-compass-codehints
It also adds code hinting for many compass mixins...
Thanks! Very helpful!
I tried to install but failed...
Removed the ZXP package, just install using the .mxi . If it gives you warnings about not being signed just say ok and ignore them and it should work. I have tested on mac and PC using DW 5.5
I have added some extensions for dreamweaver and its working fine for me and I found it at http://webdesignsolutions.co.in/sass-extension-to-dreamweaver
I hope this will work for all. Try it once.
I've not been able to find a solution to this anywhere.
I'm using CS6 (creative cloud) on a win7 PC.
I've followed through all of the steps that are posted in a couple of the solutions above - editing MMDocumentTypes.xml and both of the Extensions.txt files. I've noticed that all of the suggested solutions refer to earlier versions of DW, not CS6.
LESS and SCSS files both open in DW following this, but I don't get any nice code colouring or hinting. Any help would be appreciated.
AHA!
This DW extension works for me:
http://www.adobe.com/cfusion/exchange/index.cfm?event=extensionDetail&extid=2756522#
