Hi, I'm using Premiere SC6 on windows 7, 64bit with m2t HDV video files. I've tried every export codec but when I import the exported file back into Premiere, and compare it with the original, there is always some quality loss. I'm just wondering what other people are doing about getting a decent export?
Thanks for any help.
I have an m2t (HDV) file on the timeline, then File - Export:
Format: Quicktime.
Video Codec: Uncompressed YUV 8 bit 4:2:2 (also tried 10 bit).
Basic Video Settings: 1920 x 1080.
Field Order: tried all three (upper, lower and progressive) (progressive gave the best result.)
Aspect: Square Pixels.
Frame rate: 25.
Render at Maximum depth: tried both ticked and not ticked.
Advanced Settings: all default (nothing ticked).
Bitrate Settings: no limit on data rate.
Use Maximum Render Quality: ticked.
Thanks Harm.
Acctually my last comment is not true, as Resolve does take mxf, cin, ari, dpx, r3d and some others of that ilk.
But I've just tried exporting mxf from Premiere and I'm dammed if I can see any difference on importing. So it looks like that might do the job, as long as Resolve makes it look decent on export.
Thanks for your help Harm. I probably could do with finding a way to export AVI without quality loss though.
We are always looking at which codecs people are using and which we should include.
Hint Hint works alot better here -- https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
Download and install this http://avid.force.com/pkb/articles/en_US/Download/en423319
I believe the DNxHD is under the QuickTime list
Eric
ADK
Jim: here are the screen shots:
Very strange.
Try this. Export out a TIFF, Targa, PNG or other lossless image file format of the same frame from each clip; original and Uncompressed. Bring those stills into Photoshop and use the eyedropper on the same section of image. I'm curious what the numbers will show.
transcendental, a couple of questions come to mind:
Is your footage:
1) shot progressive or interlaced?
2) captured from HDV tape or ingested from memory cards? (if captured, it could be interpreted as interlaced when it's really not)
3) matching your sequence settings? (program monitor may not show inconsistencies, but an export will)
If what you mean by quality loss is that little blur we see in the screenshots, I think your problem has nothing to do with the codec used. It might be caused by field dominance not being interpreted correctly, a field-order mismatch between footage and sequence, or stretching from anamorphic HDV to full-frame HD.
Neil Bastin
Post-Production Director
Jam Media Producers, Inc.
Hi Jim,
Right, I exported the original capture and the uncompressed AVI export as two tiff files and took them into Photoshop. I chose a mid-luminance green area on the leaf and eye-droppered it. Here are the results:
Original: R:111, G:150, B:91, Y:79%
AVI: R:111, G:150, B:90, Y:80%
Here are the histograms for each:
original
AVI
Steve.
Thanks for that link ECBowen. That Avid DNxHD codec has done the trick as far as Resolve is concered. There is no perceptable difference between the image in Premiere of the original and the image in Resolve. And no difference between the DNxHD and a Premiere exported tiff sequence imported into Resolve. The great advantage of the DNxHD is of course that it's all in one file (as opposed to hundreds or thousdands of tiffs!) and the sound track is there.
I wonder if these differences are large enough to notice. Sure there are marginal differences, but since figures are presented as integers, I wonder if the internal reporting might be something like B: 90.51 versus 90.49 and Y: 79.49 and 79.51 and thus too small to notice. Notice these figures might also be B: 91.49 versus 89.51 and Y: 78.51 versus 80.49. I do think these figures differ so little as to have no discernible impact on the picture quality.
Hi Neil.
1) and 2) It's 1080i from a 1440x1080 HDV tape. The camera (Canon XH-A1) definitely records interlaced.
3) The sequence is set to 1080i25 (50i).
Regarding the AVI export, I have tried all the variations I can think of. Importing into After Effects and comparing gives the same result as comparing in Premiere, i.e. the AVI export is inferior. Progressive and Interlaced look slightly different, but I would say that neither is better.
Thanks.
Those Photoshop results tell a very different story about the "degradation" you're seeing. The most likely explanation here is that PP just isn't showing you the images perfectly accurately (something I've been saying for a long time) and there's nothing actually degraded about the Uncompressed file.
I agree with Jim. Sometimes what you see in the Premiere program monitor has to be taken as a grain of salt. Too many factors affect the realtime preview. Follow Harm Millaard's advice on players but here's another tip: you may also bring the AVI into Premiere, load it up in the Source Monitor and turn on the scopes. Compare the readings with the scopes on the Program Monitor. Much better than trusting your own eyes.
Also, if you plan on using DNxHD as an intermediate codec in Windows, others have recommended 10-bit RGB color space when exporting to Resolve. Just be careful with gamma shifts. Again, if in doubt, use the scopes.
All in all, if quality is your priority and you need the roundtrip through Resolve, you should consider making changes to your workflow. Media Encoder could be your savior.
Neil
Considering Cinema DNG is an Adobe initiative, I am real suprised this is not already on thhe list![]()
Eric
ADK
